displaying posts 626 to 643 of 643
Pages (26): first .. 24 25 [26]
Author Subject: Project PUG
chris with a pug
Post #626
you do have to cut a bit of plastic off of the catch otherwise it wont shut LOL
but they are designed to be cut like that I think.
like so
Posted 6th May 2012 at 21:14
eddy_gti6
Post #627
like so
Cool still have the 1s on my bonnet to fit 1st. When you hoping to be finished by?
Posted 7th May 2012 at 00:53
chris with a pug
Post #628
next years French car show is the aim if funds allow.
Posted 7th May 2012 at 09:12
clen666
Post #629
What do you think of the CBS fuse box? Has it simplified the wiring much?
Team 'unintentional rat look'
Posted 8th May 2012 at 21:00
chris with a pug
Post #630
I think for what it costs it is a great place to start, just bear in mind it is designed for a kit car so you might need to add a few things to it, the one problem I do see with it is there is no relay for the fuel pump, but I am going to wire one in just to be sure.
Posted 8th May 2012 at 23:42
clen666
Post #631
Hmm, might be a worthwhile purchase for me then.
Mine will be running the bare minimum so hopefully shouldn't need much more added
Posted 9th May 2012 at 10:56
chris with a pug
Post #632
for a bare minimum system its perfect, but just bear in mind the work involved LOL
Posted 11th May 2012 at 23:08
chris with a pug
Post #633
So I did a fair bit on Puggy this week so I should update.
Got a big parcel through this week containing the rear quarter windows and the rear.
and fitted
Very happy with them although they aren't a perfect shape.
I finally drilled the holes and bolted the battery box down.
Then next I started the wiring for the standard fuel pump.
I cut all the cables to the right length and fitted the seals
then I did the crimps
I didnt take any more of making it up but the seals push down in the hole and then a flap shuts down on them.
Here is it fitted with the grommet fitted.
I then thought I would do a nice simple job and fit the brake switch, how wrong was I, now the dash bar is fitted the steering column and the bit it bolts to has to be removed.
I did that and fitted the switch. and ran the cables
Then the big job of the day I started the wiring for the front lights, horns and washer bottle.
I decided to adapt the connectors from the original loom as it seemed to make more sense than tracking down all the different connectors new.
I just cable tied it underneath the front cross member.
I need to wire in the drivers side and the washer motor, which is quiet clever, power it one way and it runs the front, change polarity and it does the rear.
One little gadget I brought and its really good is a heat shrink gun thing.
I am off on holiday tomorrow so wont be any updates for a couple of weeks.
Posted 19th May 2012 at 22:08
playboyb
Post #634
Awesome project mate, now following this thread Smile
306 1.8 xs moonstone blue-SOLD
306 gti6 supercharged china blue-SOLD
406 coupe D9 3.0 V6-SOLD
Posted 22nd May 2012 at 21:20
chris with a pug
Post #635
So another update.
Fist off I removed the ignition barrel. So out came the angle grinder.
Then I attached the new indicator stalk.
I invested in one of these, if you do intend on rewiring a car then you should buy one.
Then I wired in the relays in the engine bay.
The two bright orange ones are for the heated windows, the others are for the ecu/sensors and the other is to start the car.
I will tidy them all up next weekend, I just ran out of time this weekend.
If you are going to take on something like this, then I really recommend CBS.
there catalogue alone has lots of wiring info and diagrams in which are really helpful.
I rang them this week with a missing bulb from a switch and I had the replacement the next day and on top of that he spent 20 mins on the phone just going over the best way to wire stuff. Really helpful and a good company with quality parts.
Posted 10th Jun 2012 at 10:55
Post #636
That indicator stalk is well retro LOL
Posted 11th Jun 2012 at 13:23
chris with a pug
Post #637
So I managed to get a fair bit done this weekend, but not many photos I am afraid.
First off my jubilee clips turned up so I whipped off the rear wheel and fitted the fuel filler elbow.
I then cut and tidied up the relay wiring and fitted the fuse for the ECU/sensor relay
The oil catch tank was refitted and I now have most of the wiring done for the lights in the engine bay.
Posted 17th Jun 2012 at 18:53
chris with a pug
Post #638
So I got in from work about 6 tonight and the weather was so nice I thought I would do a few hours on her, was still out side at 10 but hey was worth it getting the light loom finished.
Here are a few pics
I used the original grommet to get through the inner wing, just made the hole slightly larger.
I'll get out there soon and get it all p clipped in but its slowly getting there.
Posted 18th Jun 2012 at 22:20
chris with a pug
Post #639
I have been doing a few evenings out side on here lately, just doing all the little jobs that need doing.
I cut the wires and tidied up the rest of the loom for the lights and also terminated the wires for the relay into the connector.
I am not sure if people will ever used the sealed crimp connectors, I have used several differnt types in this project, so I thought it might be handy for other people if I did a quick how to.
first off cut the cable to the required length .
Slide on the rubber seal (do this before stripping the cable)
Strip off 5mm or so of insulation
crimp on the terminal
then slide the rubber seal down
then crimp the rubber bit in place
the connectors are all marked up so I have my list of what terminal is what
I also put terminal blocks on to the stalk
I also put one on the dials, but I forgot to take a picture of that.
I then turned my attentions to the dash,
I cut out a new centre bit
Fitted it and the dash pod
but after sitting in the seat and getting it to a confortable position, I have found I cant reach the buttons very easily, so I emailed a company local who do fibre glass dashes but no answer so I thought I would have a go.
I dont really do stuff like this often, but I thought about it and had a few ideas and settled on the following.
Went to B and Q and got the following
Basically I am going to make a mould out of the hardboard and then make a fibreglass pod from that.
I started it today, but is going to take a while to get it right, but I am pleased with what I have so far.
It will need a lot of filling and sanding, but its getting there slowly.
Posted 30th Jun 2012 at 18:30
chris with a pug
Post #640
So I best update this.
I am still buying bits and pieces so slowing getting all the bits I need, but the list is still huge.
I managed to finish the mould for the dash pod.
and here are the pics:
After I finished all the wood work and counter sinking all the screws I got the poly filler out
As you can see from the above I cut a hole out, this is so I can get under the pod gauges to fibre glass them in so it hopefully makes it stonger.
Here are a couple of the gauge pod
I then spent a few hours getting the filler all rubbed down
And finally it got a few coats of varnish
Sorry I haven't got any pics of it varnished, but it just looks like the above just shiny.
Next step is to give it a good coat of wax then a coat of release agent, then I can get it fibre glassed, hopefully I can get this done this week end.
Posted 2nd Aug 2012 at 17:10
Post #641
Welcome back no get some updates on this beast
Posted 9th Mar 2016 at 09:43
Post #642
nice Big grin
Creating wiring looms from scratch has surely got to be the fastest way to see a sane man to the Loony bin in record time Crazy LOL
Thumbs up
Posted 9th Mar 2016 at 10:39
chris with a pug
Post #643
Lol well it has never been said I am normal.
Just moved so once the house is all sorted need to get on this. Really struggling with a dash, might just end up folding a piece of aluminium.
Posted 9th Mar 2016 at 11:12
