Author Subject: Cambelt change, now won't start (now with vid)
ben306
Can you get the timing out enough that it won't start after changing the cambelt?
Pins lined up fine, turned over by hand fine. Nothing appears to be hitting etc. No nasty noises when trying to turn over but sounds like its possibly retarded and not quite firing right, its trying.
Have I f**ked it up (well actually a neighbour/ex mechanic AA patrol, came out to help and kinda took over when I was at the tensioning stage so not entirely sure if he did anything different to what I'd have done).
Matter of belt covers off and try again with the timing pins?
My 306 Rallye Project Thread
Lap of Anglesey Coastal
3 sisters circuit
Few laps at Blyton
Posted 2nd Jan 2021 at 12:18
marksorrento205
Did you undo the cam pulleys and adjust them to suit? Was the bottom pulley ok and not subject to slipping so the timing pin hole was out of position?
Posted 31st Dec 2020 at 19:26
ben306
Yeah. Loosened the cam pulleys and rotated clockwise. All 3 pins in ok.
Going to get a solid bottom pulley just to make sure.
3 sisters circuit
Few laps at Blyton
Posted 1st Jan 2021 at 07:23
jeffers Forum Admin
Ben, I know this may sound daft but as your car has been parked up for a while I feel I should ask.... has it been run recently? Or has it not run since you parked it up?
Team Running Engine again!
Team Negative Camber!
Posted 1st Jan 2021 at 10:36
ben306
Was running fine right before. Been firing it up and letting it turn over and run up to temp etc.
I swapped the motors about a few days before so I had more room to work on it
3 sisters circuit
Few laps at Blyton
Posted 1st Jan 2021 at 15:11
marksorrento205
Not unplugged anything and left it off or removed the spark plugs for ease of turning it over and broke a wire to a coil pack connector or anything daft like that? Fuel pipes ok?
Posted 1st Jan 2021 at 16:47
ben306
Fuel is good. Checked that. Not unplugged anything.
I might try sort a video
3 sisters circuit
Few laps at Blyton
Posted 1st Jan 2021 at 17:28
jeffers Forum Admin
Sounds odd, must be something broken or disconnected...
Posted 1st Jan 2021 at 19:06
ben306
I'll try grab a video tomorrow
3 sisters circuit
Few laps at Blyton
Posted 1st Jan 2021 at 20:28
ben306
jeffers Forum Admin
Any update on this Ben?
Posted 10th Jan 2021 at 13:43
ben306
I've been on my arse with covid unfortunately so only just getting over the worst of it. Still a major effort just climbing the stairs. Hopefully if we get a dry weekend over the next few weeks I'll try have a check of the timing etc. I've now got a solid bottom pulley as well.
3 sisters circuit
Few laps at Blyton
Posted 20th Jan 2021 at 15:38
ben306
Managed to take a look at this over the weekend.
Exhaust cam was 6 teeth out!!!!
I've managed to sort it and some how it appears its not caused any damage. From now on Im doing all my own stuff and keeping "help" at an arms length
3 sisters circuit
Few laps at Blyton
Posted 1st Feb 2021 at 09:22
Are you sure the exhaust valves have not slightly bent?
Posted 1st Feb 2021 at 19:29
marksorrento205
Christ on a bike. Hope you have recovered ok too!
Posted 1st Feb 2021 at 19:54
He managed to sort it. Popped a vid up on facebook
Posted 2nd Feb 2021 at 12:52
ben306
Time will tell but sounded ok when I fired it up. Theres a vid on the gti6 FB page.
3 sisters circuit
Few laps at Blyton
Posted 2nd Feb 2021 at 14:25
