Author Subject: Electrical gremlins
blandy
Got a few issues on my 6. It’s benn stood for many years so in the process of recommissioning it. Got it to run yesterday with the help of a new fuel pump. With the ignition off the headlights flash randomly I’m assuming this is alarm related but no siren - keys are correct etc as will not start if I move the immobiliser ring around the key.
2nd fault is the brake lights flash the indicators and dimm the dash - where is the main earth for the interior as premusin* a earth issue. The engine Is about to be pulled next weeked to do a cambelt and general bay freshen up so will go over all the earths in there
Posted 28th May 2018 at 18:07
mocinim
2nd fault could be the rear light cluster interiour circuit board
Thay go manky and cause allsorts of issues
Main interior earth is in the drivers foot well under the fuse box just right of the pedals
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 29th May 2018 at 18:00
jeffers Forum Admin
The first issue will be a dodgy alarm siren, the have a battery in if I remember rightly which fails. Disconnect the siren and if I remember correctly the problem goes away.
Team Running Engine again!
Team Negative Camber!
Posted 29th May 2018 at 19:28
blandy
Thanks I’ll give it a go
I thinning I have a spare set of lights so will give them a whirl
Posted 29th May 2018 at 20:28
