Thanks
Team Running Engine again!Team Negative Camber!
Now appearing at a Trackday near you!!
| Author | Subject: Wiring diagram |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
I’m looking for a copy of the engine bay wiring diagram if anyone has it? And before anyone says it yes I’ve done a search but the actual diagram doesn’t appear to be on here since photobucket decided to start charging. I’ve had a nose round the net and can’t seem to see it so wondered if anyone has a copy on here?Thanks ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
I’ve just texted ....Paul Vincent [CULLY] for you ...He will have a look in a bit ...great bloke He’s your man |
jeffers
quote: [quote="Day666"]I’ve just asked Paul Vincent for you ... He will have a look in a bit ... He’s your man Cheers Damo, you’re a Gent! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
what do you want the wiring diagram for the engine loom or the layout drawing or both?or what are you looking for specifically as the drawings arnt general drawings they are specific |
jeffers
I’m after the engine loom from the front inner wing upto and including the ecu plug and engine itself so I can identify rev counter feed, switched lives etc. Basically to wire an aftermarket ecu.________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
cully
right ok that will be split over several pages probably,have you the production code RPO number for the car? ive added you on FB as it may be easyer to get info |
jeffers
quote: [quote="cully"]right ok that will be split over several pages probably, have you the production code RPO number for the car? ive added you on FB as it may be easyer to get info TBH I’m nowhere near the car as in around 200 miles away! Il messenger you matey! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
naah a single diagram will cover that, http://www.306gti6.com/forum/showthread.php?id=150807 even if photobucket has stopped free hotlinking you can still find the images if you go to the image page. this might be useful too as it has a pinout for the round plugs https://www.205gtidrivers.com/forums/topic/114881-gti-6-engine-loom-wiring-guide-help-information/ ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jeffers
quote: [quote="welshpug!"]naah a single diagram will cover that, http://www.306gti6.com/forum/showthread.php?id=150807 even if photobucket has stopped free hotlinking you can still find the images if you go to the image page. this might be useful too as it has a pinout for the round plugs https://www.205gtidrivers.com/forums/topic/114881-gti-6-engine-loom-wiring-guide-help-information/ Cheers Mei! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
cully
thats a very usrful 9ne Cully, 1c02a and 1c02b are the two main loom plugs to the chassis legs.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
cully
cully
chassis plug IC02A larger one ![]() pin 1 M444 permanent earth pin 2 1070 Alternator warning light pin 3 C120 Reverse light switch pin 4 220 Reverse light switch pin 5 CC1 pin 6 123 lambda switched live pin 7 426 rev/tacho speed pin 8 100 Starter motor switched live pin 9 480 engine fault light pin 10 400 Coolant temp gauge pin 11 401 coolant temp gauge pin 12 410 oil pressure warning light pin 13 140 obd socket pin 14 414 oil level gauge pin 15 415 oil level gauge pin 16 B155 pin 17 141 obd socket pin 18 120 fuel pump switched live pin 19 411 oil temp sender pin 20 465 vehicle speed sensor pin 21 427 pin 22 403 water in diesel feul detector info pin 23 435 fuel gauge GPL info |
cully
Chassis plug IC02B smallerpin 1 808 additional heating request pin 2 8061 cooling water temperature unit command pin 3 8055 air con regulation control pin 4 1234 air con compressor relay control pin 5 pin 6 8071 compressor cut off switch relay pin 7 pin 8 820 IMMO signal pin 9 821 IMMO signal pin 10 822 fuel relay pin 11 pin 12 109 pin 13 402 water level info pin 14 |
I knew Cully would come up trumps ...he’s always around helping everyone....hope we can pay him back one day ...top fella |
jeffers
Absolute legend Paul, thanks that’s a great help! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
fatlapit
Whats immo________________________________________ |
quote: ...[quote="fatlapit"]Whats immo Immobiliser |
cully
quote: [quote="fatlapit"]Whats immo immobiliser signal its not a switch pair it is an encoded lock/unlock signal from the security box to the ecu |
quote: Whats immo In My Modest Opinion ________________________________________ ![]() |
