Author Subject: Rallye wont start
jaymes306
Hi & Thanks in advance guys
Got a rallye which has been fitted with a xsara vts engine. The engine had the 137 tooth belt set up with plastic tensioner.
main question does the xsara have a different flywheel as after converting to the older type pulleys with the 10mm's and the metal tensioner with 136 tooth belt the engine wont fire. Chugs and bangs as if it wants too which leads me to think timing is at fault. Timing has been checked numerous times with alloy pulley, no way it could be out.
any ideas?
Regards
Posted 26th Dec 2017 at 15:32
Cjwatson27
Has this only happened since you did the belt swap ? Or is this a replacement engine you’ve fitted ?
Posted 26th Dec 2017 at 17:16
jaymes306
Its a replacment engine from someone on here, was previously charged (low boost) so was deffo running, its had valves etc done recent by the looks of it. compression seems fine. ive obviously done the belt change before fitting the engine so its the only thing i can think of
Posted 26th Dec 2017 at 17:24
Same flywheel
Fuel lines round the correct way ?
When you changed the belt I assume you got the correct mount for the manual adjuster ??
Posted 26th Dec 2017 at 17:56
jaymes306
Correct mount fitted from a knackered engine i had laying about, Fuel lines correct way around
Posted 26th Dec 2017 at 18:09
rich_w
Have you got spark and a pulse on the injectors?
Contact Details:
07732 822546
Posted 26th Dec 2017 at 18:12
jaymes306
yeah, checked the spark, all 4 fine. found one of the injectors to be duff so replaced it. all 4 now spraying
Posted 26th Dec 2017 at 18:14
Well if you have spark fuel and air it should fire so check compression
Also are you using the Gti6 injectors ?
Posted 27th Dec 2017 at 16:02
rich_w
If you have spark and fuel but it's not firing, I would check the cam timing and compression.
Silly question, is your battery good?
Contact Details:
07732 822546
Posted 27th Dec 2017 at 18:39
lee306rallye
Another silly thing to check when I refit my engine a few years ago I went to start up and had chugging and banging but it wouldn't run more than 2 seconds. I checked the earth leads from battery to the gear box and also on the chassis legs. Sorted them out and it fired and ran perfectly
http://www.306gti6.com/forum/showthread.php?id=163869
Posted 27th Dec 2017 at 20:32
jaymes306
Update, Ive re done new earths, changed the engine loom from another ph2 6 i had in the yard, switched back to the 137 tooth belt set up still nothing, It coughed once for a split second and thats it. compression test shows 14 bar across all 4. spark plugs are soaked in fuel so i removed inlet so i could see valves opening and closing which they are. Ive still got a spark and injectors are working so now im still scratching my head?
i dont suppose anyone has a photo of there rallyes fuse box and relays? Wondeing if maybe someone has pinched a relay or fuse since the car was in a corner doing nothing for a long time
cheers
Posted 29th Dec 2017 at 20:43
mocinim
Presuming you have double checked all the relay and connections
When you changed the loom
Have you tried a alternative duel relay ??
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 29th Dec 2017 at 23:42
cully
"as after converting to the older type pulleys with the 10mm's"
on the early cam pulleys i think the centre boss is specific to inlet or exhaust they are not swappable
although they fit!
i maybe wrong
the later pulleys being stronger are the ones i would run with now as i had a failure with the earlier type
Posted 30th Dec 2017 at 00:06
pug_306
Have you got a spare unlocked ecu? If so I would try that and the double relay behind battery box
1992 205 GTi6
205 Turbo 340bhp
Posted 30th Dec 2017 at 09:32
jaymes306
tryed 2 ecu sets on it and have 3 double relays here. i switched them to another 6 i have here and it all works fine on that one
Posted 30th Dec 2017 at 12:24
tvrfan007
Timing not 180 out is it?
If you are sure on timing, have spark and fuel with good compression it can only be a bad sensor like crank or cam, something that's needed to start. It sure which of the two is essential for start, crank I would think.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 1st Jan 2018 at 01:01
quote:
[quote="cully"]"as after converting to the older type pulleys with the 10mm's"
although they fit!
i maybe wrong
yes you are wrong, both are the same on an RS head, j4R has one the same as RS and one different hub.
Posted 1st Jan 2018 at 08:58
quote:
[quote="tvrfan007"]Timing not 180 out is it?
I too had thought this...Yes
However, if the crank sensor was faulty then you wouldn't get a spark.
Posted 1st Jan 2018 at 10:04
demondriverdan
For the sake on sanity, have you checked the inertia switch? Just press the red button and see if it fires up? I'm pretty sure it wouldn't be sparking / pumping fuel if the switch is off but you never know.
Rallye Race Car
Posted 1st Jan 2018 at 19:22
marksorrento205
It was duff / incorrect plugs that were fitted. Different set fitted and job done Thumbs up
Posted 1st Jan 2018 at 19:24
Glad the solution was found. Thumbs up
Posted 2nd Jan 2018 at 14:10
