Author Subject: Polyurethane Lower Engine Mounts
I've got two spare (new, unused apart from testing to check fit) lower engine mounts, one in the right size for the V6 engines - 65mm outer diameter:
And one in the larger 70mm size for most XU setups.
They're made from 95A shore polyurethane. but either side of the solid core is honeycombed to soften the mounts in warp and axial modes, so they're far more comfortable than a normal 85+ shore poly mount, on my V6 there's barely any more vibration than an OE mount even on a cold idle.
The centre inserts - the solid looking part in the centre - are honeycombed internally too in a more open pattern so for small movements the mount is softer and progressively stiffens up under more movement - and other inserts are an easy push fit should you wish to have a harder/softer setup later on without removing the mount.
Centre tubes are machined from ally billet.
£50 each including delivery
Posted 14th Sep 2017 at 22:56
65mm mount sold, 70mm XU one still available.
Have a single set of polyurethane bushes + plastic inserts for a 406 front subframe left too if anyone randomly wants some Big grin
Posted 27th Sep 2017 at 17:07
forgot they didnt solid mount the 406 subframe, try adamb, he has a d8.5 v6 estate
Posted 27th Sep 2017 at 18:19
Any more after a 65mm mount for V6's, may have a spare one?
Still have a 70mm XU one too.
Have a set of 406 front subframe mounts as well, since the old ones usually look like this once you disturb 'em...
Come with new washers for the bottom too (although they're machined billet ally now rather than these steel welded ones):
Just in case any of you are using 406 subframes.....or have been as daft as me and bought one Wink
Posted 2nd Nov 2017 at 20:26
I bought one. She's a wafter, not a racer
Posted 2nd Nov 2017 at 22:23
If your old mounts look anything like mine did then even the solid poly ones end up with less cabin noise and vibration Big grin
Posted 3rd Nov 2017 at 03:07
