Rallye Race Car
| Author | Subject: Tube bearing locations |
demondriverdan
Does anyone have measurements for how far in the tube the inner and outer bearings should sit? Forgot to measure them before taking them out ________________________________________ Rallye Race Car |
jord294
Let you know in a bit when I'm in garage________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,868 Status: Offline |
220mm springs to mind, look at your shafts outer bearing needs to be in by 1mm. flat faces with the writing outwards too. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
200mm!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
miki4
Regular Location: Cologne Registered: 09 Nov 2015 Posts: 393 Status: Offline |
Yes, also had 20 cm in mind for the inner bearing as I recently replaced the bearings in my beam. 20 cm from the beginning/face of the tube to the beginning of the bearing.Outer bearings about 1mm in as welshpug said, so you can see the chamfer in the beam tube. |
demondriverdan
Perfect, thanks guys!________________________________________ Rallye Race Car |
