displaying posts 26 to 44 of 44
Pages (2): 1 [2]
Author Subject: Race car's engine issues
are you slackening the bolts to allow the pulleys to rotate as you tension the belt?
I have a pair of old valve stems to use as locking pins.
Posted 3rd Jul 2017 at 10:18
demondriverdan
Slacken pulley bolts so they move a bit, put belt on, tension belt, tighten pulley bolts, turn engine 2 revolutions, then check timing and it doesn't line up
Rallye Race Car
Posted 3rd Jul 2017 at 10:42
do you use a holding tool on the cam pulleys?
Posted 3rd Jul 2017 at 10:58
demondriverdan
No. How does that tool work? Where do you put the prongs?
Rallye Race Car
Posted 3rd Jul 2017 at 12:29
fatlapit
in the pulley arms
Posted 3rd Jul 2017 at 12:36
demondriverdan
Ohhh, I see. I'll get one of those as well then assuming I can find one. There's a Laser one but apparently it's crap!
Rallye Race Car
Posted 3rd Jul 2017 at 12:48
its a laser one I use, seems to work fine tbh! its a laser one pictured.
Posted 3rd Jul 2017 at 13:24
grantpipe
When I put a belt on mine was told to slacken cam pulleys and turn them hard one way then put the belt on and tension it then tighten pulleys. Sure the thread was on here. Av never had a problem.
Posted 3rd Jul 2017 at 15:40
jeffers Forum Admin
demondriverdan wrote:
Had a look over some stuff today and found a few issues.
Compression was (from L-R as I look at the engine, in bar): 12 - 10.5 - 12.5 - 12 so not great!
Plugs were also not in a great state:
Finally the exhaust cam was out of time a bit. I'm going to buy a proper locking kit rather than the drill bits you see here as I tried to re-time it today but it moved again for some reason. Clearly I'm doing something wrong so will give it another shot with a proper kit.
I use M6 capheads to lock the pulleys, 20mm long iirc tighten them up to the locking tab and never have any issues with anything moving....
Team Running Engine again!
Team Negative Camber!
Posted 3rd Jul 2017 at 20:41
miki4
Post #35
Yeah, you need to install a locking tool to the cam sprockets to hold them in place while slackening and tightening their bolts. If you don't do this, you put unevenly distributed stress on the cambelt which evens out (at least to some extent) as soon as you remove the locking pins resulting in the camshafts being out of time. Also, after you slackened the bolts, before putting the new belt on, turn the cam sprockets fully clockwise so there is enough room for them to turn back while tensioning the belt.
The official locking tool for the cam sprockets from Peugeot is this:
I used one of that type which worked very well:
http://www.ebay.com/itm/Twin-Camshaft-Sprocket-Holding-Tool-For-Timing-Belt-/190304956565
Posted 4th Jul 2017 at 00:34
Post #36
not ideal as the thread diameter is not a perfect 6mm and they will bite into the soft alloy of the head and not sit straight, what you need is a smooth steel pin.
regardless of that, they shouldn't be in when you tighten the bolts fully.
Posted 4th Jul 2017 at 10:17
miki4
Post #37
Just for clarification. With the locking pins you lock the camshaft so it doesn't move. When you loosen the sprocket bolts, the sprockets can move independantly in relation to the camshafts for some degrees so the tension on the cambelt can distribute evenly while tensioning. As soon as you tighten the sprocket bolts back up you need to hold the sprockets still too.
Posted 4th Jul 2017 at 14:15
demondriverdan
Post #38
Yup, I know to not have the locking pins in place while tightening or you risk breaking the locating lug thing behind the sprocket!
Rallye Race Car
Posted 4th Jul 2017 at 14:33
demondriverdan
Post #39
Bit of an update. I re-timed the engine at the weekend which was much easier with the new tools! I'm chasing up with Omex about a throttle position sensor as I could have a faulty one. Seeing as they last emailed me 12 days ago and have just said they'll "get back to me shortly", I'm not exactly happy with them! I know Chris has had some issues with them recently as well.
The other thing I've noticed recently is the cold map idle is lower than it should be. It was mapped to be 1500rpm on cold map dropping to 1250rpm on the normal map whereas it's now idling at 1300rpm on start up and slowly rising to 1400rpm, which is odd.
Rallye Race Car
Posted 17th Jul 2017 at 15:57
Post #40
shouldn't need to idle like that with a standard engine, even my 2.2 doesn't!
iffy tps and any slight vac leak or mixture variance to when it was mapped can/will do that though.
Posted 17th Jul 2017 at 16:31
demondriverdan
Post #41
We didn't spend much time on idle mapping as it doesn't make a big difference on the race car. I'd rather the time be spent mapping it at the rev range that's useful than idling!
TPS I'm hoping to replace and vac leak is certainly possible. I was planning on replacing all the pipework for the vac stuff anyway so will make that a priority.
Rallye Race Car
Posted 17th Jul 2017 at 17:32
Post #42
Good Luck Dan Thumbs up
Posted 17th Jul 2017 at 19:22
fatlapit
Post #43
Bloody omex are the bain of my life. Buggers cost me a fortune after another failure
Posted 17th Jul 2017 at 22:05
demondriverdan
Post #44
More of an update. I changed the TPS and have re-done the vac pipes so it goes straight from the vac pump to the servo with a small cap over the inlet manifold take off, none of that has made a difference. It's still idling lower than it should be when cold and slowly climbing up.
The other thing I've noticed is a weird "tink"-ing noise from the engine, you can hear it here at the beginning of the video: https://www.youtube.com/watch?v=ra01b5tfR5k
Rallye Race Car
Posted 1st Aug 2017 at 10:03
Pages (2): 1 [2]
