displaying posts 1 to 25 of 44
Author Subject: Race car's engine issues
demondriverdan
A few of you might have seen in my project thread but the race car's engine is quite down on power and is generally having a few issues. For background, it's spec is:
Pocketed pistons
BP260H cams
45mm Omex bodies (not Jenvey copies)
Satchell inlet
Longmans P&P head
Standard exhaust manifold with Piper back and middle box, no cat
Wasted spark with HT leads and NGK BKR6EK plugs
When the car was first mapped it made 183bhp at the hubs which was a reasonable amount. Over the course of last season we've felt it was getting slower in a straight line and this was backed up by it making 157bhp at the hubs last weekend, quite a drop! It was the same dyno and the same guy that did both runs and the mapping itself so hopefully fairly consistent. The biggest difference between the two runs was outside temp, it was about 2 degrees last year and 30 degrees this year, although the dyno is supposed to account for that.
The mapper said this year that the car was running a bit rich compared to what he expected and suggested it could be cam timing or exhaust system failing. Cam timing is pretty easy to check so I'll get round to that. The exhaust sounds the same so I'm not sure on what else I can do to see if it's falling apart?
The other issue I'm having is when hot (i.e. just after a session) the car will splutter and not idle at all. On rev it's ok but is quite brutal transitioning from 0 throttle to a small amount (car lurches when throttle kicks in). It will also "hunt" a bit but I can see the throttle %age changing even with my foot off the pedal. I think most of these are related a dodgy TPS so I'll try a new one of those to see if it fixes it.
Summary:
- Down on power significantly and running rich
- Cam timing?
- Broken exhaust?
- Dying after track session and very rough off - on throttle transition
- Broken TPS?
Any ideas or anything anyone else can think of?
Rallye Race Car
Posted 26th Jun 2017 at 15:51
What ecu are you using? - can you plug a laptop in and monitor the throttle position to see whether it's mis-reading at random? I think mine may be doing this.
Have you got a wideband lambda sensor? When I had mine mapped the mapper was commenting on how accurate my aem gauge was in comparison to his, it saved my engine recently when I noticed it was running too lean, so a worthwhile investment if you haven't got one yet.
Could you try a new fuel pressure regulator?
Have you done a compression test to check all the cylinders are healthy?
Posted 26th Jun 2017 at 16:39
fatlapit
I`ve had this turned out to be a broken wire for the tps
Posted 26th Jun 2017 at 16:41
demondriverdan
ECU is Omex 600. I can see the throttle position moving without my foot on it on the dashboard as my digi dash gets data from the ECU.
I've only got a standard lambda. I had a wideband briefly but I wasn't using any of it and my mapper said it wasn't really worthwhile so I swapped it out again and sold it. If I can get the data from the ECU, a narrow band should still give me an AFR value though?
Haven't tried a new FPR. It's a 3.5 bar sensor from Omex and only 18 months old so shouldn't have failed, but something to check if needed.
I'm going to do a compression / leak down test soon to see if that reveals anything.
Broken TPS wire is possible, my wiring loom is a bit s**t and needs redoing.
Rallye Race Car
Posted 26th Jun 2017 at 16:47
fatlapit
basically I lost the pink wire iirc which lost me my modulation.
Posted 26th Jun 2017 at 16:50
Don't forget fuel issues ?
Pump on way out or down on Pressure like Mei had when Sandy mapped his ZX...
Something simple can cause all sorts of issues Whistle
Posted 26th Jun 2017 at 21:08
demondriverdan
Pressure is fine, I have a fuel pressure sensor and it consistently reads 3.5 bar
Rallye Race Car
Posted 26th Jun 2017 at 21:07
Well that's my 5p worth Thumbs up
Posted 26th Jun 2017 at 21:11
demondriverdan
I appreciate it! Smile Little p**sed off it's lost power after all the money I've spent but it was my first go at building an engine so not massively surprising.
Rallye Race Car
Posted 26th Jun 2017 at 21:12
I'd be running it on 7 heat range plugs at least, have you whipped them out and checked the condition?
does sound like a dodgy tps or wiring to it, the value shouldn't alter at all.
narrowband lambda isnt any use to the Omex ecu unfortunately, I keep my AEM wideband connected to my DTA all the time and it does trim at low throttle inputs all the time.
Posted 26th Jun 2017 at 21:45
demondriverdan
Plugs were quite black last time I took them out. Do you have any recommended alternatives? I'm not that clued up on heat ranges etc.
Sam (the mapper) said something along the lines of the lambda not doing much on the car so maybe that's because as you say, the narrowband isn't much use to the Omex. Presumably though if I change lambda I'll need to have it remapped?
Rallye Race Car
Posted 27th Jun 2017 at 09:17
no need to have it mapped if you fit a wideband, you can just use it to monitor fuelling, its just a tickbox to turn on lambda trimming, not sure on the parameters in Omex but your mapper should know, by the sound of it you need a session on the rollers to see what's up, from personal experience I'd only use Sandy even if it is a bit of a trek.
I run a BCR8ES as I have a lot more compression, I ran BCPR7ES on my standard cammed engine.
black plugs is showing its over fuelling for some reason or another.
Posted 27th Jun 2017 at 10:41
demondriverdan
I've had 2 mapping sessions (due to manifold change) and each cost me £600, how does Sandy compare to that?
I've thought about going to Track and Road in Essex as they've got a reasonable reputation? Part of me things if I'm going to have another mapping session it would be worth doing a couple of other changes as well (slightly bigger injectors, swirl pot fuel system, maybe new exhaust as well)
Rallye Race Car
Posted 27th Jun 2017 at 10:43
fatlapit
s**t man i hope you got a full day for 600 quid
Posted 27th Jun 2017 at 10:52
demondriverdan
Don't even go there, I'm still annoyed about it!
Rallye Race Car
Posted 27th Jun 2017 at 10:53
Sandy is £300 at SRD or £350 at ARM BMW.
Posted 27th Jun 2017 at 13:05
demondriverdan
Is that per day? Hoping not per hour Big grin
Rallye Race Car
Posted 27th Jun 2017 at 13:18
per day yes.
he can often knock one of his own engines out in an hour or so though if its a similar spec to one he has done before Razz
he may charge a little more if bodies need balancing and cam timing checking etc, but if you can present a well prepared car with as little issues as you can that makes things a lot smoother.
fixed rate pressure regulator, pre fitted lambda easily removed bumper and stuff like that.
Posted 27th Jun 2017 at 13:22
demondriverdan
Only a 4.5 hour drive from the workshop! Big grin
Not sure how similar the spec is but it's fairly generic. The P&P head is perhaps the biggest variable as it wasn't done by him so is a little unknown.
I've got an external FPR, if I get a wideband lambda that could make things easier, taking the bumper off is a 2 minute job!
Rallye Race Car
Posted 27th Jun 2017 at 13:33
blandy
I normally go to Northampton Motorsport as there most local to me and very good although they are £100+ vat per hour.
Although for £300 a day id be tempted to drag it down to Sandy
demondriverdan
Had a look over some stuff today and found a few issues.
Compression was (from L-R as I look at the engine, in bar): 12 - 10.5 - 12.5 - 12 so not great!
Plugs were also not in a great state:
Finally the exhaust cam was out of time a bit. I'm going to buy a proper locking kit rather than the drill bits you see here as I tried to re-time it today but it moved again for some reason. Clearly I'm doing something wrong so will give it another shot with a proper kit.
Rallye Race Car
Posted 1st Jul 2017 at 18:25
fatlapit
So your running super rich
Posted 2nd Jul 2017 at 12:19
demondriverdan
Yea, I'm guessing I'll need to have someone tweak the map, more money to spend!
Rallye Race Car
Posted 2nd Jul 2017 at 21:47
miki4
Hopefully the bores aren't damaged yet if it was running rich. But the compression values support this. :l
Posted 2nd Jul 2017 at 22:06
demondriverdan
Probably! It needs to survive 2 more races before I can strip it down. If it's buggered, I'll need to think about a new bottom end
Rallye Race Car
Posted 3rd Jul 2017 at 09:32
