The rad itself seems to be on the crap side, I had a plastic hose connector break within the first 4 days and the replacement seems to leak (at least, it hisses) where the top of the plastic overflow tank meets the body...
displaying posts 1 to 25 of 33
| Author | Subject: Oil hotter with aluminium rad |
mekapaedia
Newbie Location: Vigo Registered: 19 Jul 2016 Posts: 19 Status: Offline |
Hi guys, long time listener first time caller. I've had some issues with my GTI-6's cooling system and the local dealership here replaced my old and poorly working stock rad with an aluminium one from a local company here in Vigo. Usefully, water temps do seem to be lower but when pushing on the oil temp gets much much higher, into the 120s whereas before they stubbornly stayed around 90. Any ideas?The rad itself seems to be on the crap side, I had a plastic hose connector break within the first 4 days and the replacement seems to leak (at least, it hisses) where the top of the plastic overflow tank meets the body... |
if its leaking take it back.how hard are you driving to get 120?! ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mekapaedia
Not that hard - as I said before it was around 90 (maybe 100 at times?). Driving habits haven't changed. |
miki4
Regular Location: Cologne Registered: 09 Nov 2015 Posts: 393 Status: Offline |
Check if the oil/water heat exchanger is connected to the cooling system. Could be they used a rad for another 306 without the respective port.I'm only getting to 120 after some minutes of full chat on the Autobahn. |
mekapaedia
Which one is that? Passenger side at the bottom?EDIT: to be specific, LHD passenger side |
miki4
mekapaedia
Checked... it's all connected up. Thinking of just biting the bullet and installing a mocal cooler, aiming to visit the Nürburgring in August and that's about the last place you'd want an issue. |
you shouldn't need an oil cooler on a standard car for just a ring lap, its the GP track which is hard on cars.I would get a nissens or Ordonez rad ordered. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mekapaedia
Is the Valeo any good? I am sourcing the rad fans from a guy near here (because they don't work either...) and he is parting out his 6, says his Valeo is decent and available.'EDIT: If the water temps are fine but the oil is not, how would better radiator make a difference? |
deeturbo
Regular Location: Leighton Buzzard Registered: 22 Feb 2003 Posts: 283 Status: Offline |
I'm thinking the outlet to the oil heat exchanger might be blocked. I've seen some rads with the outlet but sealed on the inside, if that make sense? |
mekapaedia
Well on the last rad when that specific fitting broke it definitely emptied all the coolant out, should I check if the hose to the exchanger seems to have liquid in it? Btw... when the engine revs I can hear something like air being compressed or pushed out somewhere, is it just the overflow tube on the rad? A little coolant comes out sometimes but I assume that's by design. |
Cjwatson27
Can you get warm air out of the heater ? ________________________________________ Old pugs don't die they just get faster |
mekapaedia
Yep, no issues there. |
mekapaedia wrote: Checked... it's all connected up. Thinking of just biting the bullet and installing a mocal cooler, aiming to visit the Nürburgring in August and that's about the last place you'd want an issue. Not a bad shout, the oil temps do get pretty high on track if you don't have a proper cooler on them from personal experience, but I guess a lot of that depends on how much abuse you give the car. ________________________________________ Goldie the track car. |
mekapaedia
Went to the official dealer today to get them to take a look... to me, the hose from the rad to the heat exchanger seem to lack pressure but they said it was all normal. They told me that with 90 degree water temp 120 oil is pretty normal... and that it's largely down to my crapped out radiator fans. Bit suspicious of that but we'll see. |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
mekapaedia wrote: Went to the official dealer today to get them to take a look... to me, the hose from the rad to the heat exchanger seem to lack pressure but they said it was all normal. They told me that with 90 degree water temp 120 oil is pretty normal... and that it's largely down to my crapped out radiator fans. Bit suspicious of that but we'll see. They're talking shizen, 120 oil temp is getting close to the oils breaking down point. I'd look more closely at the oil/water heat exchanger, also random one but the oil temperature transmitter is worth checking, just to rule it out? ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
mocinim
Seasoned Pro Location: The Darkside of bedford :) Registered: 09 Jan 2015 Posts: 2,307 Status: Offline |
Does it smell feel really hot or are you just going on the gauge??________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
fatlapit
120 degrees the oil will be useless unless its decent oil.I fing the gauges on the 6 fairly accurate tbh ________________________________________ |
mekapaedia
Just based on the gauge. Engine gets hot a lot because it's hot here and the fans don't work so well... but I don't smell oil fumes or in fact any bad smell.Oil temp gauge seems really logical in its movements, doesn't move suddenly and warms up with the engine... how would I diagnose a bad sensor if the gauge seems okay? I'm thinking of swapping this rad for a nissens... just don't really want to spend the 110 euro. |
its worth it an also sounds like yours is faulty so should go back anyway.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
miki4
It's likely that the new rad is s**te because the oil temperature was normal before the repair. Probably there is not enough flow through the oil heat exchanger. Or it got blocked during the repair.However, a Nissens rad is worth the money. |
3rd time lucky
Seasoned Pro Location: maidstone Registered: 23 Apr 2007 Posts: 1,879 Status: Offline |
I've heard different coolants mixed can block some waterways in the engine. I would get that Valeo rad and coolant flush it. Failing that, nissens rad ftw. And oil cooler if you plan to hoon it quite a bit as they do get rather hot quickly. Although as said, shouldn't be necessary on a standard engine unless doing trackdays.________________________________________ DIABLO GTI-6 - Legend - NILE GTI-6 - SoldCHERRY GTI-6 P1 SUPERCHARGED - Broken up BLACK RALLYE - Sold 205 Dturbo xud9 work horse - Dead CHERRY RALLYE - new toy |
1. Nissens rad2. Good proper coolant, flush it first and bleed it correctly 3. Oil cooler with a thermostat take off, invest it's worth it 4. Good fully synthetic oil 120 oil temp is feck all. I get worried above 140... But then the oil I use works to over 150 ________________________________________ Nothing to see here |
mekapaedia
What would be considered "proper" coolant?And what would be a good oil choice? I was thinking of getting "Fuchs Titan Race Pro S 10W-50" put in. |
ale624
Regular Location: bristol Registered: 02 May 2016 Posts: 180 Status: Offline |
Hahaha, f**king stealerships man. 120 is normal, got to be having a laugh!if everything was fine before the rad swap, then it has to be the new rad. coolant is the pink kind. for Oil i use Full synthetic 5w40, although 10w50 should be perfectly fine. never seen my oil gauge even think about going over 95, even while giving it some beans. Coolant can creep up a bit, especially while sitting in traffic, but never seen my oil gauge go over 90 while just around town. Normally it hits 90 and stays there. |
