Author Subject: Which OE rear shocks is BEST?
orallye
Hello everyone,
My GTI-6 need to replace its rear shock absorbers.
I want to buy OE parts only - and i need advice about which manufacturers makes the BEST OE rear shocks-
Im hesitate between BILSTEIN B4 or MONROE?
Which one is better?
THANKS!
Posted 1st May 2017 at 07:07
Peugeot
Posted 1st May 2017 at 08:09
orallye
Peugeot OEM is now MONROE :
Cherry Buell wrote:
Went to a peugeot dealer recently and was told that 5206 TE was now superseded with a new part no. don't have it to hand but will post it tomorrow. I ordered the part and got what appears to be monroe monotubes just a generic shock. They look nothing like the stubby originals and after fitting them to a d turbo hdi I must say I'm not happy. I'd be looking at something else if I were you. They do the job just but I wouldnt write home in excitement about them
Posted 1st May 2017 at 08:14
miki4
What was the the former OEM for 306 dampers? Bilstein B4 should be a good choice for OEM replacement although I've read somewhere that they have a slightly higher damping rate than original if that's a criterion. But don't pin me down to this.
Posted 1st May 2017 at 14:22
peugeot have made peugeot dampers for years.
if they supply aftermarket for older cars now I would try Citroen,
Posted 1st May 2017 at 14:25
mocinim
Oem can still be found not cheap though what sort of money are you spending
mocinim has attached the following image:
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 1st May 2017 at 22:46
jord294
Got genuine pairs here still in bag.
But as Andy says, o/e aren't cheap
Posted 2nd May 2017 at 08:19
