| Author | Subject: Wheel bearings with track use |
stevec33
Newbie Location: Peterborough Registered: 18 Jan 2013 Posts: 41 Status: Offline |
Does anyone who runs a gti 6 on track struggle with wheek bearings? My car seems to ruin the nsf wheel bearing on every trackday i do! Is it possible something else is wrong or is this just what there like? Cheers |
quite likely a worn drive flange or poorly manufactured CV joint.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
fatlapit
Location: STOCKSFIELD Registered: 02 Nov 2010 Posts: 3,040 Status: Offline |
Nah never had an issue.Is the hub ok?? ________________________________________ |
miki4
Regular Location: Cologne Registered: 09 Nov 2015 Posts: 393 Status: Offline |
Probably not the issue but unbalanced wheels put an unneccessary strain on the bearings at higher speeds. |
deeturbo
Regular Location: Leighton Buzzard Registered: 22 Feb 2003 Posts: 283 Status: Offline |
Are they being installed correctly?I've seen a few people press bearings in via the middle race instead of the outer when pressing in to the hub. |
mocinim
Seasoned Pro Location: The Darkside of bedford :) Registered: 09 Jan 2015 Posts: 2,307 Status: Offline |
deeturbo wrote: Are they being installed correctly? I've seen a few people press bearings in via the middle race instead of the outer when pressing in to the hub. Best guess is this if its that frequent ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
stevec33
As far as i know all the surrounding parts are ok, I specifically asked it to all be checked out the second time. They have been replaced by two separate mechanics due to timing issues for getting it to a trackday so i would expect it to be unlikely for them both to get it wrong |
The best most mechanics are going to do is have a quick look over it before they slap the bearing in. Get some verniers or bore gauges and check the hub and the upright.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
stevec33
Gunna get it checked out more throughly this time, most likely to be the drive flange by the sound of it. |
fatlapit
Id say the hubs goosed________________________________________ |
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
I killed a wheel bearing, wheel, droplink, tracking and two tyres at pugfest does that count? |
