Author Subject: How to remove sideskirts
weemangti
So never had any off before how are they held on and best way to remove them thanks
Posted 6th Feb 2017 at 13:11
fatlapit
remove the bottom door seal drill the rivets out
underneath drill the rivets out
on the rear quarter it will be clipped and bonded on
Posted 6th Feb 2017 at 13:12
weemangti
Okay that great thanks
Posted 6th Feb 2017 at 13:49
mocinim
Source new clips first some may brake Thumbs up
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 6th Feb 2017 at 15:42
russbez
they will Whistle
My Rallye project thread
Posted 6th Feb 2017 at 16:02
fatlapit
plenty bodge tbh ive no clips on mine makes no difference
Posted 6th Feb 2017 at 16:18
mocinim
Trick is to slide the skirt not to pull may save one or two lol
Posted 6th Feb 2017 at 16:34
weemangti
New clips and rivets on way from peugeot
Posted 6th Feb 2017 at 18:19
mik
russbez wrote:
mocinim wrote:
Source new clips first some may brake break Thumbs up
they will Whistle
Spelling police Thumbs up
One of the 2 types of plastic clips near the rear arch are NLA. If you are careful you can resurrect them by replacing the double-sided spongy tape stuff. Sometimes you see the clips on ebay. This is covered in my project thread.
I replaced the rivets with stainless rivnuts in case they need to come off again in the future. I drilled out the alloy bit of the rivet carefully, and cut the protruding bit off with a dremel, and caused no damage to the sill at all. You will unavoidably end up with the other end of the rivets in the sill. Use the opportunity to blow some cavity wax in there, the lance will fit in the rivet holes. Best to remove inside trim to do the rear bit as the sound insulation goes right down into the sill. Also you can access the inside half of the sill (it is centrally divided with a stiffening piece) through the front footwells.
Cherry Rallye SOLD
Posted 6th Feb 2017 at 20:13
mocinim
Cheers for the spell check my typing has become lazy its my phone spell checker simular to rear parking sensors lazy and annoying Smile
Where did you sorce your rivnuts ?
Posted 6th Feb 2017 at 21:24
mik
Quote from my project thread:
"I used 16mm length bolts which was perfect.
Bolts are M4, washers are M5 (for total approx diameter of original rivet heads as the holes in the skirts are quite big), and stainless splined rivnuts have M4 thread with 6mm outside diameter (1mm wall thickness)".
Also see page 9:
http://www.306gti6.com/forum/showthread.php?id=136766&page=9
Rivnut link I used is here: http://www.ebay.co.uk/itm/170778239746?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Just checked and it still works.
Cherry Rallye SOLD
Posted 7th Feb 2017 at 07:21
weemangti
So removed the side skirt today was purity easy thanks for all the pointers, and to my delight there is no horrible rusty holes behind it.
Posted 8th Feb 2017 at 17:16
demondriverdan
Replacing the rear clips are a pain, I thought I had done them on mine but the glue became useless again so now it's loose. I might try some double sided strips or a bit of tiger seal to help hold them on.
Rallye Race Car
Posted 8th Feb 2017 at 21:08
