displaying posts 26 to 50 of 80
Pages (4): 1 [2] 3 .. last
Author Subject: binned it :(
mocinim
sageman wrote:
that's the inner CV joint, right side shaft is a two part unit, you have most likely lost many of the needle rollers from it, if you've been lucky and they're all there then all you need is an inner cv boot and wash all the crap out of it.
to check the rear you need to take the wheel and brake pads off.
so these needle rollers where do they belong are they going to be ratling around my gearbox now or not
wash all the crap out of what and what crap i assume you mean mud etc but i never left the tarmac so i doubt there is any
Needles are in the universal joint bearings the three bearings on the end of that section of shaft , they look ok but without having hands on its hard to tell
The crap is the grease on the shaft end and in the boot degrease and replace with fresh cv grease and new boot rubber
The rubber boot maybe split so will need replaced
If you take of the rubber that is still attached to the car it will reveal the cup the end it goes into. make sure the spring is still in there its pretty simple you need to remove the end of the shaft that is attached to the hub at the wheel end dismantle it and refit a new boot ( look for the faq)
Or buy a second hand shaft from ??? And refit
Your gearbox should be fine is the seal leaking ???
If it is buy a new gearbox seal
Try and get some pics of the steering rack and tie rods id replace the tie rod end as a matter of course there around 15bucks for a good one lemforder are good or febi
Switched my hub bearing changed the tie rod end changed the cv boots and the shocks top mounts changed the springs n put b8s etc today its fairly simple once you get going i dont have a garage all is done on the drive so have become fairly swift in operation
But can be easily done in a couple of days if you new to these jobs
Bonus if you have a garage Thumbs up
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 5th Feb 2017 at 23:24
sageman
noted thanks
1976 Reliant Kitten
1985 Reliant Fox Tandy campervan
1998 GTI-6
1993 Citroen XM sei V6 (barn find)
Posted 6th Feb 2017 at 21:57
sageman
hmmmm
so the shock looks like this and the bit that attaches to the bottom wobbles a fair bit however that rust tells me that something might have been up for a while ive always had a knock too and that wheel was alredy warped slightly
dont really have the tools to get this off however the track rod looks straight so might just leave it for now
when it comes to this inner cv joint thing im sutch an idiot i thought this this was over the gearbox but after getting a propper look (and looking on the faq's here a few days before to be honest) it not ha ha
im guessing though that it will have to come out to get a new boot on anyway what size is the nut that holds it into the wheel for referance 32?
also what is that white cable/pipe thing its been damaged (how badly i couldnt see diddnt fancy sticking my head under there with only that jack
1976 Reliant Kitten
1998 GTI-6
Posted 12th Feb 2017 at 16:40
you need a pair of dampers by the look of it, ideally remove the inmer half of the shaft to get a new boot on, 35mm socket.
get to halfords and buy a trolley jack and axle stand set.
which bit wobbles?
Posted 11th Feb 2017 at 11:57
mocinim
Thats the clutch cable chap and its 35mm hub nut
Bilstien b4 damper by the look of it fyi Thumbs up
Posted 11th Feb 2017 at 12:16
Cjwatson27
If you need the parts and willing to travel you can have them from me for nowt but I ain't posting
Posted 11th Feb 2017 at 21:45
mocinim
What parts have u got ???
Posted 11th Feb 2017 at 21:49
Cjwatson27
s**t off 2 gti6 and that f**ked rallye I'm homeless now so it's all needs to go just to clear the yard plus I need room for my BMW r53 collection.
Posted 11th Feb 2017 at 22:07
mocinim
Whatts app me bud will come down n get stuff dont mind posting on to others if the pay the postage
Posted 11th Feb 2017 at 23:29
Post #35
From experience you could well find that the arm and the subframe are both bent after an impact such as that. Wouldn't surprise me if the hub is bent too considering it folded the bottom ball joint in half and bent the bottom of the shock
Posted 11th Feb 2017 at 23:43
sageman
Post #36
bit of an update i got the ball joint on today and drove it the short distance over the bridge to our island as it was kind of in the way where it was (and i had to park a 15 miunite walk away which was anoying)
i diddnt notice any obvous bending to any other parts and the wheel was sitting streight so hopefully bending the ball joint and damper absorbed the energy
someone asked which bit wobbles......... dont know whats its called the part that is attached to the bottom of the damper that whole part wobbles around the damper dont know how to explain that better
appart from that that crappy jack i pulled out of a crashed 306 at the scrappy years ago finally died so i couldent get any further
1976 Reliant Kitten
1998 GTI-6
Posted 12th Feb 2017 at 16:38
Post #37
ah yeah the damper body is very dented in the clamp so you need new dampers.
Posted 12th Feb 2017 at 18:23
sageman
Post #38
little update for you
so the hub (is that right) seems to be the bit thats bent interestingly its bent to the side like this but spins freely and isnt warped just bent inwards like this which seems strange
disk and pads have seen batter days i think
shot absorber
1976 Reliant Kitten
1998 GTI-6
Posted 18th Feb 2017 at 19:22
Post #39
looks like just the stub pin is bent not the arm then, if the bearing is still smooth you can re-use it by drifting the pin out.
dont be tempted to pull the bearing off as the inner race will stay on the pin and damage the seals
Posted 18th Feb 2017 at 20:16
sageman
Post #40
is there a thread with pictures what it looks like inside there i did have a look but couldnt find one
1976 Reliant Kitten
1998 GTI-6
Posted 18th Feb 2017 at 20:51
RetroPug
Post #41
To be honest it might be less hassle to just get a known good pair of 2nd hand ones off ebay/someone on here. They aren't expensive at all.
Posted 18th Feb 2017 at 22:57
sageman
Post #42
what are we talking about here disks or dampers
dampers were replaced 12k ago according to paperwork so i would only need the one i would have thought
im assumeing disks should be done in pairs should they
1976 Reliant Kitten
1998 GTI-6
Posted 19th Feb 2017 at 13:23
barrym
Post #43
going off that pic of your discs you have even more problems
Black Rallye occassional toy
Posted 19th Feb 2017 at 14:30
mik
Post #44
The thing is about accident damage is that it is not always very obvious that something is damaged, the shock of impact can manifest itself in ways you do not expect. I would replace anything that might be affected as a matter of course - this stuff should be cheap enough with all the people on this forum willing to help you out, free parts, getting stuff off scrap cars etc. Don't skimp out by trying to keep something that _might_ be OK. Do it nice or do it twice.
Cherry Rallye SOLD
Posted 19th Feb 2017 at 15:07
RetroPug
Post #45
I meant hubs rather than trying to replace just the stub pin etc.
Posted 19th Feb 2017 at 16:33
sageman
Post #46
so the whole rear beam then?
so now ive had a good look i now know whats needed
front damper
front driveshaft (i figure its easer to just replace it with a known good one and give this one to someone who knows what theyre doing with it part exchange type thing hopefully
rear disk (and pads) (do i need to do both sides)
side skirt thing
two wheels (i know one is warped it was before the crash i assume the other could be too)
and whatever is decided for the back
1976 Reliant Kitten
1998 GTI-6
Posted 19th Feb 2017 at 17:59
Post #47
Not sure if you've replaced your hub/hubs or not but found a pair of 18mm ball joint ones same as yours still
With the abs sensors attatached on the Bay
Posted 21st Feb 2017 at 09:14
sageman
Post #48
Not replaced them no just the balljoint I'm guessing you think it's an idea to do so
1976 Reliant Kitten
1998 GTI-6
Posted 21st Feb 2017 at 13:00
Post #49
With them taking such a knock for the sake of £40 you may as well should only take about and hour or so to change them too!
Posted 21st Feb 2017 at 16:12
mocinim
Post #50
As above good advice Thumbs up
Posted 21st Feb 2017 at 16:23
