displaying posts 1 to 25 of 80
Pages (4): [1] 2 3 .. last
Author Subject: binned it :(
sageman
roundabout
too much speed
100% my fault wasnt even wet Sad
1976 Reliant Kitten
1985 Reliant Fox Tandy campervan
1998 GTI-6
1993 Citroen XM sei V6 (barn find)
Posted 4th Feb 2017 at 10:39
cully
OOps! bad luck are you going to fix her?
looks like you,ve done the rear beam too
vision in my head of a 306 in mid air over the roundabout with dixi horns sounding!
Posted 4th Feb 2017 at 10:48
sageman
would like to fix it just depends on costs as i doubt i could do most of what needs doing
yep i think ive bent something at the back to
1976 Reliant Kitten
1998 GTI-6
Posted 4th Feb 2017 at 10:51
mocinim
A bit of spit shine shell be right as rain
Is it just running gear or is the chassis damaged
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 4th Feb 2017 at 11:28
sageman
i think its just running gear i havnt banged the body on anything any chassis damage will be mounting points i looked at the shock mount thing in the engine bay that looked ok
1976 Reliant Kitten
1998 GTI-6
Posted 4th Feb 2017 at 11:32
looks like driveshaft, driveshaft seals will be knackered!,
ball joint wishbone possibly anti roll bar?
its not rocket science to pull apart and have a look Wink
should be able to do it yourself Smile
Posted 4th Feb 2017 at 11:49
sageman
its more a lack of time than anything else tbh couldent even do the work needed on the kittens MOT this year
working on machanics isnt too much of a problem for me im sitting here trying to fix the engine on my boat at this very muinite
1976 Reliant Kitten
1998 GTI-6
Posted 4th Feb 2017 at 11:56
alcon
sageman wrote:
roundabout
too much speed
That's the best turning circle I've ever seen on a 6!!....at least you'll be able to go round mini roundabouts now LOL
Seriously though, it doesn't look too bad a job or too expensive. As you say, at least there is no panel damage otherwise it would be a different story. Get it fixed Thumbs up
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 4th Feb 2017 at 12:51
sageman
if im honest im going to need a friendly local who knows more about these than i do to see what needs doing
1976 Reliant Kitten
1998 GTI-6
Posted 4th Feb 2017 at 12:59
driveshaft seal will be fine, will need a shaft though, and a wishbone.
stub pins tend to bend not the arm, hopefully the caliper/bracket is ok.
I don't think Ryan is a million miles from you, he'll have plenty of bits to get her back with it wheels pointing the right way.
Posted 4th Feb 2017 at 15:08
sageman
1976 Reliant Kitten
1998 GTI-6
Posted 5th Feb 2017 at 03:25
looks even easier, balljoint and a driveshaft.
Posted 5th Feb 2017 at 07:51
mocinim
Whats the rear beam like ??? Any pics
Posted 5th Feb 2017 at 09:27
Nose
Was going to say the same, Ryan (pug_306) is only down the road from you in Thetford, pm him, sure he''ll be able to help bud Thumbs up
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 5th Feb 2017 at 10:38
Yeah good shout!
You could have that fixed in an hour or so! Thumbs up
Dont forget to drain the engine oil! Razz
Posted 5th Feb 2017 at 11:16
Yeah good shout!
He'll have everything you need beam and all!
Posted 5th Feb 2017 at 11:17
gnrlee wrote:
what?!
Posted 5th Feb 2017 at 11:33
sageman
umm whats this on the end of my driveshaft looks to me like it belongs inside the gearbox not outside it
rear beam
much like my kitten then
1976 Reliant Kitten
1998 GTI-6
Posted 5th Feb 2017 at 12:04
that's the inner CV joint, right side shaft is a two part unit, you have most likely lost many of the needle rollers from it, if you've been lucky and they're all there then all you need is an inner cv boot and wash all the crap out of it.
to check the rear you need to take the wheel and brake pads off.
Posted 5th Feb 2017 at 12:16
Cjwatson27
Free parts if you want to travel to pick them clean ?
Posted 5th Feb 2017 at 17:05
mocinim
The rear beam going to take the longest to repair/replace but that should be simples also
Good luck with the fix keep us posted Thumbs up
Posted 5th Feb 2017 at 18:53
mechanical_repairs
Most common only bent the stub, smack it out and check.
Carl
Posted 5th Feb 2017 at 19:56
mocinim
Carl
Heres hoping Thumbs up
Posted 5th Feb 2017 at 20:03
sageman
so these needle rollers where do they belong are they going to be ratling around my gearbox now or not
wash all the crap out of what and what crap i assume you mean mud etc but i never left the tarmac so i doubt there is any
1976 Reliant Kitten
1998 GTI-6
Posted 5th Feb 2017 at 22:25
that shaft hasn't come out oft he gearbox, its two feet over the other side of the car.
Posted 5th Feb 2017 at 23:01
