Author Subject: Fuel gauge fault
mocinim
Hi gents have a fuel gauge issue it wont drop down past just under the quater even when its empty its not the fuel pump its self as ive just changed it (yes it was like it before the change )
How do i fix this little issue
Cheers Smile
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 13th Jan 2017 at 17:13
demondriverdan
Have you got a spare set of clocks you could put in to see if the problem is there?
Rallye Race Car
Posted 13th Jan 2017 at 17:15
mocinim
No unfortunately not am after what it could be all ideas really so i can go through an eliminate etc
So you think it could just be the clock ?? Gauge !
Posted 13th Jan 2017 at 17:17
mocinim
Any other ideas gents Smile
Posted 15th Jan 2017 at 13:40
demondriverdan
I had a fuel gauge issue ages ago and it turned out to be the clocks, put another set in and it just worked. Just wanted to let you know it was a problem I had had in case you hadn't thought about it Smile
Rallye Race Car
Posted 15th Jan 2017 at 15:45
mocinim
I will give it a go cheers dan
Posted 15th Jan 2017 at 16:28
ale624
Anyone know the specs for the voltage on the fuel level sensor wire?
You could check that with a multimeter at the clocks?
Posted 15th Jan 2017 at 17:56
pug_306
Swap the clocks over with your other one easily done without removing steering wheel :-)
1992 205 GTi6
205 Turbo 340bhp
Posted 15th Jan 2017 at 18:30
mocinim
Can the fuel gauge be removed individually or is it a clock change dash thing
I would like to keep my original dash etc
Posted 15th Jan 2017 at 18:53
cully
fuel gauge is a motor soldered to the main dash clocks PCB all the relevant electronics are on the main PCB too
Posted 15th Jan 2017 at 19:07
cully
have you messed with the needles on the clocks? have you pushed them on to far scrapping the backplate
Posted 15th Jan 2017 at 19:04
mocinim
No not been in there will get it open and see if i can spot anything worst comes to worse ill re soldier a new motor cheers cully
Probably needs a clean or a dryjoint has occurred
Posted 15th Jan 2017 at 19:53
