Author Subject: Proposed FAQ - starting after storage?
mik
Team,
A proposal for an addition to the excellent FAQ resource.
We hear a bit about what to do about starting a car after it has been in storage for a few months, to prevent it firing until the oil pressure is up to prevent excessive engine wear in those first few seconds. Some mention disconnecting the crank sensor.
For people like me who are not conversant with these methods, could some of you whip up a FAQ maybe with some pics to describe how to disconnect something to enable it to turn over for a bit before starting?
Cheers.
Cherry Rallye SOLD
Posted 13th Dec 2016 at 19:09
jeffers Forum Admin
Why disconnect the crank sensor? If it was me I'd pull the plugs out and disconnect the fuel pump relay. The engine will spin over with minimal pressure on anything and will still build oil pressure, rather than disturb the crank sensor. Personally that's the route I'd take and in fact have done in the past. Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 13th Dec 2016 at 21:58
I'd just tap the crash switch or unplug it in the engine bay = job done but then I'd just fire the cvnt up and not worry about it
Posted 13th Dec 2016 at 22:55
heliosphan
Whenever I've needed to do this (which was frequently, over ~4 years) I just disconnected each of the wiring plugs from the 4 injectors. Takes less than 10 seconds and prevents fuel from entering the engine in the same way as removing relays.
Posted 14th Dec 2016 at 10:11
miki4
That's the way I did it, too, after replacing my broken engine. Disconnect each injector's plug, remove spark plugs, squirt about a teaspoonful of engine oil in each cylinder through the spark plug holes. Wait a minute or two for the oil to flow round the bore and then let it crank with throttle wide open so there is minimal load on the engine until the oil pressure lamp goes out. When cranking, give it a break every 5 seconds or so.
Posted 14th Dec 2016 at 11:22
mik
No idea if that is the best way or not, that's why I'm asking.
Cherry Rallye SOLD
Posted 14th Dec 2016 at 11:45
RetroPug
I own a 306 that this man put back on the road after 9 years of being sat on a driveway. Not sure what he did on first startup.
Engine is great and runs quietly.
Posted 14th Dec 2016 at 12:24
This is the absolute best method. Yes
Posted 14th Dec 2016 at 23:17
fast_eddie
MMM----looking forward to trying this on my stored Mi 309 after 10 years!
Wish me luck eh?
Obviously I am going to turn here over by hand on the bottom pulley!
Posted 14th Dec 2016 at 23:41
Very wise indeed. Yes
Posted 29th Dec 2016 at 10:58
Stan should write this guide has his Manlove never moves Laugh
Posted 29th Dec 2016 at 13:37
fatlapit
Just start the f**ker it will be ok
Posted 29th Dec 2016 at 14:35
Checked oil levels put a new battery on it fuel in and turned it over / fired up on the button did turn it over for a while with out any fuel so I guess oil would of been round the engine
Posted 29th Dec 2016 at 14:37
mik
Pull the fuel pump relay and crank it for 10 - 15 secs?
Cherry Rallye SOLD
Posted 29th Dec 2016 at 15:54
