Author Subject: Missing subframe bolts
oliverharveyuk@hotmail.co.uk
Anyone know the part numbers or what spec of bolt I would buy to replace these bolts? Here is the side with the bolts:
Without:
I guess that's not normal...
98 Blaze 6 - Current
Posted 27th Nov 2016 at 19:22
not normal no LOL
you need p-bushes too
Posted 27th Nov 2016 at 19:32
3509 56 btw, +69mm long m12x1.75 bolt with captive washer.
if you need to move the car take that loose bolt and stick it in the other side, torques up to spec obviously.
Posted 27th Nov 2016 at 19:46
I'm suprised I haven't notice any weird knocks whilst driving round... Yeah was looking into getting Berlingo bushes as they seem to be better according to a few forums.
Posted 27th Nov 2016 at 19:47
Thank you!! Sorry you wouldn't know what the amount of torque I should tighten to?
Posted 27th Nov 2016 at 19:52
Christ that was lucky... You'll notice a big difference
Posted 27th Nov 2016 at 21:39
Think I have one somewhere? Pretty sure you can't get them from Peugeot anymore!
Posted 27th Nov 2016 at 22:17
they are sill available.
Posted 27th Nov 2016 at 22:42
mocinim
Can be obtained under restyling they are also the same bolts as used on the berlingo and 8 other peugeot models
But are no longer available as original part
Usual peugeot bollox
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 27th Nov 2016 at 22:46
Thanks lads, just ordered the bolts so hopefully my car will be nice and secure by the weekend, hopefully it's just a case of screwing them in. Do I need a washer or is the captive washer enough? Then I can get onto the important bit of replacing the clutch cable...
Posted 28th Nov 2016 at 17:10
mocinim
Captive washer is enough chap
Posted 28th Nov 2016 at 17:49
Sorry got myself a torque wrench now, anyone know what the torque setting of the subframe bolts should be? I've done them up tightish but now getting a knock on that side sometimes when turning right over bumps.
Posted 11th Dec 2016 at 11:51
manthos
Just put it in tight. good and tight
Team SUPERCHARGED
Old Project thread
Posted 11th Dec 2016 at 12:15
mocinim
85 Nm for subframe bolts chap
Subframe screws /bolts are self locking from new and ideally should be replaced every time
If re using glue them in chap stops them falling out etc
Posted 11th Dec 2016 at 13:41
jeffers Forum Admin
I think you mean loctite, as for torque settings it's a non moving part so FT will be fine. Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 11th Dec 2016 at 18:58
mocinim
Loctite or equivalent yes i wasnt refering to some form of pritstick or PVA (just incase your superstupid lol)
And supplied the Nm because it was specifically asked for as the man stated he has got himself a torque wrench
But thanks for the input all the same jef!!
Posted 11th Dec 2016 at 19:35
Thank you, they are new screws so should stay, I'll.keep checking on them and if they start coming loose I'll loctite them
Posted 11th Dec 2016 at 21:12
They do loosen over time. I check mine before every track day
Posted 12th Dec 2016 at 08:03
Never seen any come loose ever !!
Posted 12th Dec 2016 at 09:42
i have but only if they've been disturbed they need a good threadlock and not being over tightened.
Posted 12th Dec 2016 at 12:06
