Author Subject: Low clutch pedal
stevec33
My clutch pedal is very low on the 306, it works fine but only pushes a few intches, you can pull it up by hand to the correct position but it then just goes back to resting in the lower position once pressed again. Is this a common issue? Anyone know what the fix is? Cheers
Posted 25th Nov 2016 at 19:08
Had something similar but not 100% the same & it was the Clutch automatic adjustment system built into the clutch cable ...I replaced the clutch cable & it instantly sorted it ...could be a few things though ?
I run a completely different clutch & arm & now don't have a ajuster built in anymore Thumbs up
Posted 25th Nov 2016 at 20:07
jeffers Forum Admin
Clutch cable, nailed on! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 26th Nov 2016 at 00:08
Yep, clutch cable.
The adjuster dries out and gets stuck over time. Yes
Posted 26th Nov 2016 at 10:24
mocinim
Easy fix / replacement check the faq on here its pretty good
The whole job takes aabout an hour including jacking up and making tea
Ramps is best Thumbs up
Dont loose the string end
Smile
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 26th Nov 2016 at 11:44
prying the plastic clip through the aircon pipes and finding the little hole for it to feed in through the bulkhead is a pig of a job!
Tie some string to the old part that clips onto the peddle before pulling it through!
this should help you locate where it's to go once the old one has been removed Wink
Posted 26th Nov 2016 at 15:01
oliverharveyuk@hotmail.co.uk
I'll be tackling this job tomorrow if the weathers okay, got the clutch cable for £22 off car parts for less, hoping it's not too painful to fit.
98 Blaze 6 - Current
Posted 26th Nov 2016 at 16:02
Could also be some of the fingers in the clutch plate have broken. Had the same on my rallye, changed the cable but no difference until it failed completely shortly after
Posted 27th Nov 2016 at 21:37
ale624
ooh, how convenient, I've noticed mine is a bit low and i can flick it back up to normal with my foot.
might replace the gear linkages at the same time...
Posted 28th Nov 2016 at 00:38
