Author Subject: Whining gearbox possibly
mocinim
Have a wining noise coming from the gearbox believe it to be the diff possibly
What is it likely to be
Not wheel bearings but relevant to road speed pushing in the clutch makes no difference its not drastic but is sliwly getting louder
Any thoughts ???
How easy is it to change the diff and bearings whilst in situe
Cheers Smile
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 9th Nov 2016 at 07:58
fatlapit
Easy peasy to do in situ.
Pull shafts out
Undo the bolts
Done
Posted 8th Nov 2016 at 21:00
cully
Pull shafts out
Undo the bolts
Done
ha ha not quite that easy!
drain oil
remove shafts
remove battery/box/ecu
disconnect manifold cat pipe
remove gear linkages
std airbox out
support engine from above
remove top gearbox mount
release lower mount
swing engine forward untill oil filter touches radiator
you then get enough room to remove the diff casing without dropping the subframe from bellow
done it 3 times this way now fitting my ATB
got it down to a 4 hour job with no hold ups
Posted 8th Nov 2016 at 21:13
mocinim
cully wrote:
Pull shafts out
Undo the bolts
Done
drain oil
remove shafts
std airbox out
release lower mount
Awsome cheers cully do you know what part numbers the diff bearings are and what else will need replaced seals other bearings etc Sad
Posted 8th Nov 2016 at 21:19
cully
the diff case i sealed with a film of liquide gasket,
there is an oring seal around the speedo drive nose
the 2 drive shaft seals
2ltrs of oil
bearings can be found on ebay easily most peugeot box's use the same diff bearings for what i can see but do check
may also be worth getting a set of crownwheel bolts if you are removing the crownwheel from the diff itself as you may damage the threads if you dont crack them all first before winding one out
crown wheel bolts part number 9800266980 £1.72 each
speedo seal 264512 is 76p+vat
Final drive half housing bolts, M10; 41Nm 30lbft
Final drive half housing bolts, M7; 12Nm 9lbft.
Speedometer pinion adaptor; 12Nm 9lbft
Final drive extension housing bolts ; 15nm 11lbft
some box's will have a shim on the long shaft side bearing some wont
only fit what is there as if you put a shim in you need to change the nose casting as that sets endfloat
Posted 8th Nov 2016 at 22:59
wondered what the hell you meant, wining.
ohhh, WHINING, check the wear on the crownwheel itself, if that's rough then you'll need another box.
Posted 8th Nov 2016 at 23:03
Could be the main bearings or release bearing. Best put it on a two poster ramp to check where the noise is coming from.
Posted 8th Nov 2016 at 23:18
Chr1sch
mine whines too, been ignoring it for now, how loud are we talking?
Posted 9th Nov 2016 at 09:18
cully
id be inclined to drain the oil to see how much metal is in it
then try with some new oil as genuine oil is cheap
Posted 9th Nov 2016 at 10:30
mocinim
If the radio is of i can hear it at low speed as in low engine noise otherwise it cant be heard its possibly been doing it for ages but i managed to quiten the engine n exhaust down quite well so no i can hear it its a little noisier than tyre noise but with that king of circulating bearing wump wump wump sound
Posted 9th Nov 2016 at 11:39
you'll always have some noise if its stripped out and solid rubber mounts.
should try a saxo with bodies, sequential box and a rose jointed torque link and metal jointed suspension...
Posted 9th Nov 2016 at 12:38
mocinim
Its lowered but otherwise fully oem im not currently concerned but am restoring them also so am being ultra critical
And ive never done it and so fancy a go
Cheers for all the help guys
If all goes s**tty i have a couple of spare boxes Smile
Posted 9th Nov 2016 at 15:57
cully wrote:
Pull shafts out
Undo the bolts
Done
drain oil
remove shafts
std airbox out
release lower mount
Wow surely easier to just undo a few bolts and whip the subframe out and have room to swing a cat?
Posted 10th Nov 2016 at 23:10
probably easier to just remove the box.
Posted 10th Nov 2016 at 23:49
Did mine with the box on the floor as wanted it out to paint it anyway but if I hadn't wanted to do that I'd have just taken the subframe out as it's like half hours work at the very max on a ramp with air tools.
But while on the subject of diffs and what not how did people torque up the crown wheel bolts? Found it a nightmare to hold the doff still enough to get to proper torque. Debating putting it in a vice to hold it still and thought.....NOPE... £700 of diff LOL
Locked the box in gear and got someone to hold the diff down while I torqued it and still jumped out. Didn't get the specified torque but not miles off and plenty of thread lock.
Has been fine for 2 years now.
Posted 11th Nov 2016 at 16:59
pry bar across the bolt heads, though yeah, a vice will be fine, its not made of cheese LOL
Posted 11th Nov 2016 at 17:05
cully
wedge between my knees wrapped in a towel then with the torque wrench Wink
Posted 11th Nov 2016 at 17:20
mocinim
Any pics gents wiuld be appreciated just of the internals any would be great Thumbs up
Posted 11th Nov 2016 at 18:19
cully
Posted 11th Nov 2016 at 18:45
mocinim
Superb cheers bud looks stright forward how tight are the bearings
How tricky to remove and install new ones
And do they seat all the way or will a small gap be required
Posted 11th Nov 2016 at 21:00
you'll need a puller and a press to fit them, they seat fully on the diff.
Posted 11th Nov 2016 at 21:02
Yup don't think they were very tight to press on mind but still interference fit.
Haha I probably should have just used the vice but thought better of it LOL
Posted 11th Nov 2016 at 21:28
Careful you don't slip and torque your nuts.
Posted 12th Nov 2016 at 00:08
mocinim
Will use my bearing clamp kit n a shim will do nicely have a few pullers just a few dozen lol cheers again guys
Posted 12th Nov 2016 at 03:13
