Author Subject: engine idle issues
cully
Ive been having Idling issues with the car when its hot
not all the time just some times, normally after a run/track session when the car is stood cooling down on tick over with the fans forced running
it would tick over no probs then all of a sudden it would rev up, slow then try to manage then stall
I checked for air leaks with brake cleaner, replaced the Temperature Sensor 1920.K9 with a new genuine item,also changed ICV many times,
but it still did it occasionally.
yesterdays track day it did it again this time i unplugged the PAS pressure switch and it instantly cured the problem
do these switches adjust idle on load?
do they go faulty?
do i need it?
Posted 1st Nov 2016 at 16:06
mocinim
Yes
Yes
Yes
Get a new one
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 1st Nov 2016 at 16:25
cully
Ph3 switch is £45 new from Peugeot!
Ph2 ones are NFP
ph2/3 have different plugs on the loom
i have several Ph2 switch's here i may add the ph2 plug to my ph3 loom to give me the option Wink
Posted 1st Nov 2016 at 16:53
if you have a good ph2 switch just swap the plug.
Posted 1st Nov 2016 at 17:09
cully
yup that will be the plan Wink
Posted 1st Nov 2016 at 17:56
sergioiacobucci
Or just unplug it make sure you give it a bit more if parking. Thats what i do
Phase 1 silver track car
335i daily
Posted 1st Nov 2016 at 18:38
jeffers Forum Admin
Just leave it unplugged, mines been unplugged for years n never been an issue.
Team Running Engine again!
Team Negative Camber!
Posted 1st Nov 2016 at 22:00
