Author Subject: Clutch change
oliverharveyuk@hotmail.co.uk
How much would you expect to pay to have a clutch supplied and fitted along with the other bits and bobs that are a good idea to replace?
98 Blaze 6 - Current
Posted 26th Oct 2016 at 14:48
Posted 26th Oct 2016 at 15:40
mocinim
Do it yourself thats just lazy £150 tops !!!
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 26th Oct 2016 at 16:16
deeturbo
Best to replace all oil seals -driveshaft both sides, input shaft (built into the release bearing tube) I also did the crank and line seals ("hockey stick" ).
Posted 26th Oct 2016 at 18:20
I wouldn't know where to start, I wouldn't mind doing it with someone who knows what there doing but defo way out my comfort zone probably gonna go pug1off if there within the 300-400 mark then thanks for the info Smile
Posted 26th Oct 2016 at 19:34
barrym
I think 3-400 is a little low, more like £500 minimum at proper today garage rates
Black Rallye occassional toy
Posted 26th Oct 2016 at 20:18
Get the bits I'll do it cheap for you and it's a c**t of a job
Posted 26th Oct 2016 at 21:44
fast_eddie
lol--gearbox is a twat to get off and Im 'guessing' a twat to get back on again lol
Posted 26th Oct 2016 at 22:51
justsamo
It is a right arse to get off and on especially when trying to keep the fork lined up! Fresh oil and a new cable makes all the difference to!
Posted 27th Oct 2016 at 09:58
Be minimum 500 at a garage probably a lot more as book time shows over 7 hours (not that it would take me that long)
They last a long time so while it's out its worth doing both shaft seals both clutch fork bushes, changing the input shaft seal / nose cone and renewing the clutch cable. Only a genuine cable is worth bothering with cheap ones don't last. Same with a clutch get a valeo or LUK.
Posted 27th Oct 2016 at 10:28
Are all these bits available from GSF or ECP or would I have to go through main dealer? I wouldn't have a clue what most of that stuff looked like so not sure I would trust myself buying the correct parts... £500 that stings a bit... But sounds like parts will come to around £250?
Posted 27th Oct 2016 at 10:37
ecp do Dura branded cables which are same as o.e, they do luk/valeo clutches as well.
bushes are o.e only for decent ones.
Febi shaft seals are very cheap, no need to pay 5x as much for o.e, the crank I would leave unless its actually leaking otherwise you'll need to remove the flywheel as well.
release bearing guide tube ECP also do Febi items again, though here unless necessary I wouldn't do as in theory you need to check the preload on the input shaft bearing so its not that simple a job for most.
depends how fast a turnaround you want, either buy the minimum and hope for the best, and have it out of use for a few days if you need more parts.
or go full retard and buy all the stuff and get it done in one go.
don't forget o.e/Total gear oil.
book time is 6 hours, S16 was more as it was a f**ker to do due to the inlet and coolant pipework, 6 is pretty straightforward and can be done fairly quickly especially on a ramp.
I'd offer to do it if you were nearer.
Posted 27th Oct 2016 at 10:59
deeturbo
EPC have a 30% and GSF have a 47% sale on at the moment so you could pick up a cheap clutch.
Posted 29th Oct 2016 at 11:04
