TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread
| Author | Subject: What is it and can I cut it off..... |
russbez
![]() ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
russbez
Trying to get link working on a mobile!U shape piece there ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,891 Status: Offline |
Seriously???thats the jacking point and it's quite useful if you use it properly! ![]() ________________________________________ Proud Member of the ASTOR Owners Club |
not a jacking point tie down point. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Ben_W
Formerly gpm Location: Lutterworth Registered: 01 Sep 2007 Posts: 2,941 Status: Offline |
As per WP.Lash down point. Cut it off if you want. Coskev did, sure others have ________________________________________ Cherry Red Rallye .... On going OEM spec restoChina Blue GTi6 .... Weekend toy Black 208 GTi .... Wife's car now Silver BMW 550i.... The executive missile |
gnrlee
well you learn something new everyday! ![]() ________________________________________ Proud Member of the ASTOR Owners Club |
russbez
Yeh only reason I could think to keep it would be rolling roads, but iv never seen them use it.________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
mocinim
Seasoned Pro Location: The Darkside of bedford :) Registered: 09 Jan 2015 Posts: 2,307 Status: Offline |
Its a refugee stow away loop if your heading across the border best to grease it up so not to bring back unwanted clingons ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
RetroPug
It's probably not safe to jack the vehicle on that. It won't be designed to bear the load of the vehicle and might snap off, particularly as the metal surrounding that tie-down hoop can get very corroded.________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
zx doesn't have them at all.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
russbez wrote: Yeh only reason I could think to keep it would be rolling roads, but iv never seen them use it. Mine were used on the rolling road when I was getting it mapped. ________________________________________ Goldie the track car. |
It's your cars foreskin,leave it well alone! |
gnrlee
RetroPug wrote: It's probably not safe to jack the vehicle on that. It won't be designed to bear the load of the vehicle and might snap off, particularly as the metal surrounding that tie-down hoop can get very corroded. then that sounds like a great point to pin the car to the rolling road by??? ![]() I only ever use mine to get the car high enough to get the Axle stands in place! ________________________________________ Proud Member of the ASTOR Owners Club |
russbez
Some of the answers here haha.I'll prob leave it as is and just buff round it. ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
RetroPug
gnrlee wrote: RetroPug wrote: It's probably not safe to jack the vehicle on that. It won't be designed to bear the load of the vehicle and might snap off, particularly as the metal surrounding that tie-down hoop can get very corroded. then that sounds like a great point to pin the car to the rolling road by??? ![]() I only ever use mine to get the car high enough to get the Axle stands in place! Supporting the entire vertical load of the vehicle and stopping it slipping around are not the same. It's probably a tie-down for transit. Specifically what for I don't know, but possibly vehicle delivery, or delivery of the body in white to the assembly plant. It won't initially have been designed to tie it to a rolling road, will it? I am only telling you this for your own safety and wellbeing, I have seen 306s where the metal that is welded to is pure rust where water has gotten behind the underseal. Laugh at that advice all you like, but it was given to you with good intentions, not simply to be pedantic. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
mocinim
RetroPug wrote: gnrlee wrote: RetroPug wrote: It's probably not safe to jack the vehicle on that. It won't be designed to bear the load of the vehicle and might snap off, particularly as the metal surrounding that tie-down hoop can get very corroded. then that sounds like a great point to pin the car to the rolling road by??? ![]() I only ever use mine to get the car high enough to get the Axle stands in place! Supporting the entire vertical load of the vehicle and stopping it slipping around are not the same. It's probably a tie-down for transit. Specifically what for I don't know, but possibly vehicle delivery, or delivery of the body in white to the assembly plant. It won't initially have been designed to tie it to a rolling road, will it? I am only telling you this for your own safety and wellbeing, I have seen 306s where the metal that is welded to is pure rust where water has gotten behind the underseal. Laugh at that advice all you like, but it was given to you with good intentions, not simply to be pedantic. Agreed this loop was used for manyfacture and transport never for jacking and should never be I personally wouldn't EVER!!! . subframe (between the rear bolts at the oval indents ), beam and sill are the correct jacking positions ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
mik
Seasoned Pro Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
RetroPug wrote: Supporting the entire vertical load of the vehicle and stopping it slipping around are not the same. It's probably a tie-down for transit. Specifically what for I don't know, but possibly vehicle delivery, or delivery of the body in white to the assembly plant. It won't initially have been designed to tie it to a rolling road, will it? I am only telling you this for your own safety and wellbeing, I have seen 306s where the metal that is welded to is pure rust where water has gotten behind the underseal. Laugh at that advice all you like, but it was given to you with good intentions, not simply to be pedantic. If the metal around that tie-down loop is so corroded you can't safely tie it down to a rolling road, the car is probably unsafe to be on any road, never mind a rolling one. ________________________________________ Cherry Rallye SOLD |
RetroPug
mik wrote: If the metal around that tie-down loop is so corroded you can't safely tie it down to a rolling road, the car is probably unsafe to be on any road, never mind a rolling one. I'm not debating what to tie the vehicle down to a rolling road with, I didn't bring up rolling roads. My point is that it was never designed to support the vertical load of the vehicle, and that was when it was new and hadn't had any degradation. I'm simply trying to prevent anyone from hurting themselves or damaging their 306. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
mik
Agreed. ________________________________________ Cherry Rallye SOLD |
mocinim
mik wrote: Agreed. I agree with your agreement !!! ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
