| Author | Subject: Renault sport brembo calipers £165 delivered |
SOLD |
*BUMP*Have another set of these for sale for anyone interested same price as before |
RetroPug
Do you have the mounting bolts for these as I don't think there were any with the last set from memory? Can't check right now unfortunately________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
RetroPug wrote: Do you have the mounting bolts for these as I don't think there were any with the last set from memory? Can't check right now unfortunately Dude still got the bolts from the ones I sent you if you need them can post them no probs |
they are a particularly expensive size, M14 with a 1.5 pitch thread iirc.Spoken to Ben Godney about these Calipers and when they use them on a brake kit they have a top hat sleeve to take them much cheaper to bolt on even with the cost of a custom made sleeve and readily available M12 bore, which is still more than adequate, if you need some of them drop them a line, ben said they have loads. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
welshpug! wrote: they are a particularly expensive size, M14 with a 1.5 pitch thread iirc. Spoken to Ben Godney about these Calipers and when they use them on a brake kit they have a top hat sleeve to take them much cheaper to bolt on even with the cost of a custom made sleeve and readily available M12 bore, which is still more than adequate, if you need some of them drop them a line, ben said they have loads. Have a word with a Ben about doing me a 330mm bells and rotor kit dirt cheap please |
do you need brackets? best give him a message yourself and say dan and me sent you.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
RetroPug
Thanks for the advice.Ash, I'll let you know about posting. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
BUMP!Buy my s**t so I can buy more s**t with the monies |
v6saloon
Senior User Location: Ilkeston Registered: 24 Sep 2010 Posts: 619 Status: Offline |
Post #35
What's needed to fit these? would 5hey fir behind c5 steelies whth spacers?________________________________________ 205 mi16405 Mi16x4 restoration project 406 v6 saloon track car project/daily driver 508 Hdi |
aaron6
Post #36
You need to make a bracket to suit a choice of disc. I currently run the 310mm bells and rotors set up from Ash but will be machining a set of brackets so I can use the 305mm 406 coupe disc. ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
Post #37
i wouldn't use the 406 disc, not enough offset.if you must use a singld piece disc try a fiat punto abarth disc redrilled and the centre bore opened up, it works with the pendulumn bracket. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #38
Right want them gone so I can buy some shiny s**t for the megane so 125 collected or 140 delivered |
v6saloon
Post #39
Ate these a lot better than 406 brembos?________________________________________ 205 mi16405 Mi16x4 restoration project 406 v6 saloon track car project/daily driver 508 Hdi |
Post #40
yup, monoblock design and larger pad area.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
v6saloon
Post #41
any issues fitting them to a 406 anybody know________________________________________ 205 mi16405 Mi16x4 restoration project 406 v6 saloon track car project/daily driver 508 Hdi |
Post #42
v6saloon wrote: any issues fitting them to a 406 anybody know Buy them and find out |
aaron6
Post #43
welshpug! wrote: That's interesting. What size is the Fiat punto abarth disc?i wouldn't use the 406 disc, not enough offset. if you must use a singld piece disc try a fiat punto abarth disc redrilled and the centre bore opened up, it works with the pendulumn bracket. ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
Post #44
http://www.brakebook.com/bb/textar/en_DE/92228503_82/datasheet.xhtml 305mm, so you could take 2.5mm off the brackets and get more radial caliper clearance ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
aaron6
Post #45
I may just do that. It'll be quicker and easier to re drill the discs and skim the brakes. Hmmm. Cheers Welshy. ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
Post #46
cant take credit for it, Niall on the 306 forum figured that out.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #47
SOLD!!!!! |
aaron6
Post #48
Yay!________________________________________ See the sheer power and might of the lesser known burrowing owl. |
Post #49
Well you lucky buggers I have another set of these fabulous calipers for sale.All in GWO and finished in black this time! £165 posted or £150 collected |
RallyeRed
Regular Location: Northwich Registered: 03 May 2016 Posts: 353 Status: Offline |
Post #50
Pm sent |
