Author Subject: Central Locking
coffeecup
After locking the drivers side, the passenger side locks after 1minute or doesn't lock at all.
Is the a relay which controls this, where does it live?
ThanksCool
Posted 27th Aug 2016 at 15:36
RetroPug
This could be an issue with your door loom.
Posted 27th Aug 2016 at 15:52
deeturbo
Which phase is you car?
It could be relays on phase1/2 or door loom if it's a phase 3.
Relays on the phase1/2 are at the back of the rear seat bases.
Posted 27th Aug 2016 at 15:54
mocinim
This could be as simple as your door lock not being ligned up properly but is usually corrosion in the door jam wiring under the rubber gator
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 27th Aug 2016 at 16:08
coffeecup
It's a rallye, which is a phase 2 ?
So most likely drivers side door loom, under the rubber cover?
Don't really fancy doing that.
Will have to learn to slam the drivers door harder, or superglue the passenger side then.LOL
Posted 27th Aug 2016 at 16:25
6waysforward
Either the door loom has broken or you have corrosion on the pins of the connectors. Undo the connectors, spray them with wd40 and give them a good wire brush.
This sorted mine out.
Posted 29th Aug 2016 at 19:02
