Author Subject: Oh cr@p...help
Chr1sch
Gents
Just had a call from my best mate who is also a mechanic and has done all the work on the 6...
First off I trust him implicitly so don't suggest foul play...
Anyway, he's been doing my cambelt in the evenings and has gone to move the car and started it...with no belt on
So anyway, he's compression tested it and it's 190-200 across all 4 Pistons so compression I believe is ok. It's got a rebuilt Richw head on it already and 16 new valves. He's said its running perfectly but there is a slight tap.
I'm going to pop over and listen tomorrow but can you give me the best and worst case scenarios please?! (I have a trackday on the 19th!!
Posted 23rd Aug 2016 at 16:58
pugheaven
Oopps that's a big mistake but they happen unfortunately.
Probably bent half or all of the valves Sad
Posted 23rd Aug 2016 at 17:22
going to be 4 bent valves, it wont bend all 16 without the belt on as the rest will be closed
Posted 23rd Aug 2016 at 17:59
Doh note to anyone else doing a belt with the engine still in
Immobilize the car for those senior moments!
Hope it doesn't cost too much to sort pal,..
Posted 23rd Aug 2016 at 19:19
Chr1sch
Thanks, I won't be paying for the repairs, I'm just hoping it's easily and quickly fixable :-)
Posted 23rd Aug 2016 at 21:21
might as well get the seats recut to 3 angle whilst the new valves are going in and a fresh set of stem seals and clean up the face, o.e gasket and a set of payen bolts wont be too expensive.
Posted 23rd Aug 2016 at 22:11
jeffers Forum Admin
If the belt was off and it was correctly timed my bet is cylinder 3..... 2 valves....
Team Running Engine again!
Team Negative Camber!
Posted 23rd Aug 2016 at 22:30
pete_rallye
Aye, it won't be too horrendous. 2 bent valves, a set of bolts and a gasket (knocking on £50 fr a pug one now!), plus 5ish hours labour. You could do extras as WP mentions but guess you're mate is unlikely to pay, a light skim is always worthwhile though to ensure decent sealing, and a touch more compression.
Lap of the 'ring
Posted 23rd Aug 2016 at 23:34
Chr1sch
Thanks gents appreciate it :-)
Posted 23rd Aug 2016 at 23:40
the seat cutting I mention has two benefits, it'll open up the port coming into the seat and give a nicer angle.
it'll also set the valve back into the seat a little bit, which is a good thing with a refaced head as you'll pull back a bit of the lost valve-piston clearance.
Posted 23rd Aug 2016 at 23:44
This. Yes
Posted 24th Aug 2016 at 14:39
Call me suspicious...... but I do all the cam belts at my garage. You need the drivers front wheel off for starters right? So I don't understand at all why he would "go to start the car" to move it with no wheel on and the vehicle raised whilst half way through a job?
Makes no sense to me at all.
Posted 25th Aug 2016 at 07:48
Chr1sch
Quite simply he was doing me a favour and doing it in bits in the evening, so as I understand it he had the belt off and stripped down but needed it off the ramps for the day so rolled it out, but started it again to bring it back in...
Posted 25th Aug 2016 at 08:03
aaron6
Oh dear. So are they going to repair it properly?
Posted 25th Aug 2016 at 08:43
Makes more sense then. Probably just a slip of the mind in a rush it happens.
This is why once i start a belt job you don't come off it untill your at a sensible point were either it's 100% stripped and staying on the ramp can't be touched etc or you've 100% finished the belt and it can be started.
Hope he learns a valuable lesson LOL
Posted 25th Aug 2016 at 10:27
Thats just bad timing on his behalf
Posted 25th Aug 2016 at 11:11
Chr1sch
Yeah it sucks but he's a good mate and a perfectionist so it will be fixed perfectly, that I have no doubt
I went and listened to it and whilst it was always a noisy engine it clearly has a metallic tap from the right side of the head when anything above idle rpm
Posted 25th Aug 2016 at 11:14
lolol
Posted 25th Aug 2016 at 12:35
Chr1sch
Hahaha how did I miss that!
Posted 25th Aug 2016 at 20:12
Chr1sch
So 3 bent valves, but apart from that all good - its having a full head rebuild anyway so should be fighting fit for the trackday on the 19th.
Does anyone have any recommendations for headgaskets etc? OEM?
Posted 1st Sep 2016 at 15:32
hg -o.e
the rest- Payen.
o.e valves are trw.
Posted 1st Sep 2016 at 15:49
Chr1sch
Great thanks
Posted 1st Sep 2016 at 19:43
Just in time then mate!
Posted 2nd Sep 2016 at 18:14
