Author Subject: Clips on calipers
Ben_W
Formerly gpm
Guys,
What is the little clip type thing on the front calipers? As seen in this pic, slightly below and to the right of the '57' on the caliper.
Service box doesn't show them as a separate part so assume they come with the caliper. Looking at it, I'm guessing they are a holder for the pad wear sensor wire?
Posted 14th Aug 2016 at 22:29
brake pad warning light wires
Posted 14th Aug 2016 at 22:17
Ben_W
Formerly gpm
Cheers Mei, thought it would be that!
Question is then where do the pad wires plugs plug in? Couldn't see anything on my hub's etc and the current calipers and pads don't appear to have the wires
Posted 14th Aug 2016 at 22:31
deeturbo
Does this help. They plug in just below the brake hose on the hub.
Posted 14th Aug 2016 at 23:27
Ben_W
Formerly gpm
It does. I think it also explains a couple of things.
Almost certain the Rallye hasn't got these. Both of the ones I've had didn't have them.
Posted 14th Aug 2016 at 23:53
mocinim
Correct sir the rallye doesnt have this installed
mocinim has attached the following image:
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 15th Aug 2016 at 00:05
6waysforward
f**king LOL LOL LOL LOL LOL
Bit tight was it?Big grin
Posted 15th Aug 2016 at 22:59
Cut the wires off there s**te anyway and usually melt
Posted 16th Aug 2016 at 06:38
Ben_W
Formerly gpm
Don't know why they made the pads with them for the Rallye if they had nothing to plug into.....
Posted 16th Aug 2016 at 06:57
mocinim
Did they make rallye ones specially???
Was it possible to get it as an option???
Are the part numbers the same
Posted 16th Aug 2016 at 07:49
Ben_W
Formerly gpm
No idea, not looked into it properly yet.
Service box does show pads with sensor wires.....i guess they would bother making another pad without the wires for a low production number run such as the Rallye..
I'll have a look at my old pads when I get home.
Posted 16th Aug 2016 at 14:11
deeturbo
Yep the top bolt was a bit stuck lol It was difficult trying to get the bolt undone as the slider kept rotating.
Posted 18th Aug 2016 at 18:33
deeturbo
The pads on my Dturbo 266mm system come with wear sensors but the car doesn't have the wear indicator system. The wires are just cut off.
Posted 18th Aug 2016 at 18:36
