| Author | Subject: HELP with v6 cambelt |
Cjwatson27
Hi having issues with changing the cam belt on the v6 I've order a replacement belt kit and the garage say it's the wrong one something about mine having a auto tensioner and the kit having a manual one. They also say the cam belt doesn't need replacing has its been replaced recently has all the writing showing still on the belt. What do you guys think should I replace it and do I have the right can belt kit and the tensioners a revised item ? ________________________________________ Old pugs don't die they just get faster |
you can fit the manual tensioner but need to mod or replace the water pump too.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mocinim
Seasoned Pro Location: The Darkside of bedford :) Registered: 09 Jan 2015 Posts: 2,307 Status: Offline |
Get the correct kit bud how long has it been sitting around at your lock up personally id change it Call the place you got it from see if they will exchange it ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
mocinim
mocinim wrote: Get the correct kit bud how long has it been sitting around at your lock up personally id change it Call the place you got it from see if they will exchange it If the tensioner is new as is the belt id just change the belt bud ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
Cjwatson27
I've got a new water pump would that already work or do I need to order a later one ? ________________________________________ Old pugs don't die they just get faster |
Depends on the belt and tensioner you've bought. All early stuff works together, all old stuff walks together. Peugeot, Citroën and Renault ________________________________________ Nothing to see here |
You need the later pump but with the earlier larger diameter vane on it. (There's 3 pumps, early tensioner large vane, late tensioner large vane, late tensioner small vane).Or, just do what I did and chop the bit off the early pump that gets in the way of the late tensioner setup (since it's very difficult to get the early tensioner setup for reasonable money and the late one works fine and is simpler) ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
Cjwatson27
Such a ball ache this is becoming ________________________________________ Old pugs don't die they just get faster |
Did one of these in a 406 coupe for the first time a while ago. Was surprised how many cats you could swing between the inner wing and the belt once it's stripped. ________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
Cjwatson27
Not much room in the v6 once it's in the 306. Just want it finished now ________________________________________ Old pugs don't die they just get faster |
If you've already got the water pump all they need to do is chop off the bit where the big hole for the old tension fits, and the new one will go in then.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
LIke this:![]() ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
Cjwatson27
Cheers Phillip I'll show him that. Problem is he's a ford man so he's only used to rust and cast iron lol________________________________________ Old pugs don't die they just get faster |
Cjwatson27
Cheers looks like I have a new style water pump and belt kit. Well the belt and tensioner looks brand new the water pump looks old and has a leak so it's getting changed over so fingers crossed ________________________________________ Old pugs don't die they just get faster |
I've got my fingers crossed for you |
