displaying posts 1 to 25 of 35
Author Subject: Tie rods MAXED!
shabusta
Does anyone have any ideas for when you mechanically max out your tie rods
but you need an extra 5mm to get back to zero Sad
for the full story:
I hit concrete in the city the other day, bloody thing wasn't marked and I turned late.....
popped a tire in the process Crazy managed to limp to a garage rotated the tires now have an odd one on the back,
I hit the front right it is now +5mm it was +9mm but it is now mechanically maxed out.
any ideas?
Posted 12th Jul 2016 at 09:37
More than likely the rack has taken a hit and bent the tie rod.
Jack it up and have a look round, see if you can see anything obvious.
Posted 12th Jul 2016 at 09:47
Probably bent the wishbone too
Posted 12th Jul 2016 at 12:34
shabusta
does this mean i am replacing parts or i can get away with some form of tie rod extensions? (if they exist?)
the vehicle drives and feels fine currently.......
Posted 13th Jul 2016 at 00:55
You need to find and replace the bent parts.
Posted 13th Jul 2016 at 02:00
This. Yes
Posted 15th Jul 2016 at 07:38
mocinim
I would also check for damage to the subframe less likely to be bent but not impossible
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 15th Jul 2016 at 12:29
shabusta
If it is sunny I'll put the car up tomorrow.
Posted 15th Jul 2016 at 12:48
What do you mean +5mm or +9mm? Doesn't mean anything to me. You need to replace what's bent which is probably inner and outer track rods and wishbone and then get it tracked up properly.
Posted 15th Jul 2016 at 13:37
shabusta
This is what i mean.
Posted 15th Jul 2016 at 14:11
looking at that id say you have a bent strut or wishbone
Posted 15th Jul 2016 at 14:57
shabusta
great...... its like i just replaced those a few thousand KMs ago.... oh well see how we go tomorrow.
Posted 15th Jul 2016 at 14:59
also possible bent rh rear stub axle.
shabusta
any way I can actually check the rear stub axle?
Guessing I'll have to remove it to check it?
[url=http://www.306gti6.com/forum/showthread.php?id=118453]http://www.306gti6.com/forum/showthread.php?id=118453 [/url]
This is from the above thread Clicky, Group N pins better than OEM ones?
Posted 15th Jul 2016 at 16:51
woody.
Figures look pretty even on the back no?
Posted 15th Jul 2016 at 19:17
Camber's out.
Posted 15th Jul 2016 at 19:59
yep, left side looks close but right side is three quarters of a degree too upright, as is common with a glance against a kerb.
looking at the king pin angle its way too low on the left too, not sure what specifically this points to though.
the rh caster is 2 degrees out, which could point to a wishbone or strut bent back.
Posted 15th Jul 2016 at 20:07
shabusta
just to confirm when we say strut you are talking about the very expensive piece of suspension?
these?
Posted 16th Jul 2016 at 05:32
those don't look expensive, but yes.
Posted 16th Jul 2016 at 07:49
shabusta
hahaha i am a poor uni student, i only bought them because Ebay had a deal for so much % back off any purchase over $100.
Posted 16th Jul 2016 at 10:10
Stop crashing then Wink
shabusta
first car and i have only "crashed" once and i would like to call it bad luck.
Posted 16th Jul 2016 at 10:11
Castor_Troy
I call it bad driving LOL LOL LOL
Posted 16th Jul 2016 at 10:47
This implys you've crashed other cars more than once? Huh?
If your a poor student that can't afford to maintain your 306 as said stop crashing or get a push bike! LOL
You'll never have any money owning one of these and thats without crashing! LOL
Posted 16th Jul 2016 at 11:39
Cjwatson27
I found crashing 306 s is the best part of owning them
Posted 16th Jul 2016 at 11:44
