Author Subject: Oil pump chain
Bradabong
Hello, is there any way to tighten the chain mine looks awefully loose?
Thanks
Posted 7th Jul 2016 at 13:03
make sure the shim is under the pump.
Posted 7th Jul 2016 at 13:25
Bradabong
The L shaped shim is there... its not going to pull off the teeth or anything just seems slacker then I thought it should be... Thank you for the reply
Posted 7th Jul 2016 at 13:42
cully
fit a new chain if its worn
pug part no 1033 10 52links ENGINE OIL PUMP CHAIN £30 retail
Posted 7th Jul 2016 at 14:36
Bradabong
Thank you cully... Is this a timing belt removal job?
Posted 7th Jul 2016 at 15:43
cully
yes timing belt off and maybe the end seal casing
Posted 7th Jul 2016 at 16:31
pugheaven
Speak to rich w as he has found an uprated chain as a few supercharger engines have died because of this
Posted 7th Jul 2016 at 16:37
cully
there is a SC engine with a snapped updated chain over on OC
http://306oc.co.uk/forum/showthread.php?tid=34308
main thing to watch is the alignment of the sprockets which stops the chain tying to ride up
Posted 7th Jul 2016 at 17:01
pugheaven
From what i remember there was an uprated one from peugeot and then rich found a non peugeot item that was even better
Posted 7th Jul 2016 at 19:11
jeffers Forum Admin
Moved to correct section.
Team Running Engine again!
Team Negative Camber!
Posted 8th Jul 2016 at 09:12
IWIS chains.
Posted 29th Jul 2016 at 23:21
