displaying posts 1 to 25 of 28
Author Subject: Braided brake lines
Cjwatson27
Hi I'm having to get some custom brake lines made does anyone know the size and what type of connector I need to join to the original brake pipes. Also what's a good recommended length I don't have any hoses to hand to measure and would like to get these ordered asap
Many thanks
Posted 22nd Jun 2016 at 22:09
10x1.0 fittings.
as for length, you need to measure your car if theyre custom made for your car
Posted 22nd Jun 2016 at 22:14
Cjwatson27
Cheers WP I'll have to pop to the garage and have a measure up. Was really hoping the guys making them would had some idea on what I needed has I don't have a clue lol
Posted 22nd Jun 2016 at 22:18
Cjwatson27
Do they call them female or male ? Or is 10x1 all they'd need to know ?
Posted 22nd Jun 2016 at 22:19
mocinim
What lines are you replacing bud what set up custom jobs depend on your system are you using a compensator ph2 type or ph3 type
Is it of a particullar design
If you are having someone do the job they should be able to set it all up for you and supply all required
Standard sizes for brake terminations are 10.1 male to fit into the calipers and 12.1 male and female union joins originally but custom your own size
Rear brake compensator takes 10mm and 12mm
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 22nd Jun 2016 at 22:33
Cjwatson27
. It's only for the front calipers I know the connector for the cailper end and the company is a willwood stockist so that's cool. Just need the fitting to connect up the the original pipe on the body of the car. Length wise I though 14 in if there too long I can tie them out of the way
Posted 22nd Jun 2016 at 22:43
mocinim
545mm i think chap flexy hose length at the front
Posted 23rd Jun 2016 at 00:08
Cjwatson27
Do you know what the connection is on the part that joins to the pipe on the csr Andy ?
Posted 22nd Jun 2016 at 23:01
mocinim
http://www.ebay.co.uk/itm/172022444263?clk_rvr_id=1050597052064&rmvSB=true
Check this out chap believe spec to be the same 10.1 dia but there is thread length etc on there bud
Hows those wheels Wink
Posted 22nd Jun 2016 at 23:17
The end that joins to the pipe at the car end is m10x1 female as far as I'm aware, as it sits in that bracket with the spring loaded clip thing.
Posted 23rd Jun 2016 at 06:10
demondriverdan
Related note, anyone know where to get braided lines for the 310mm Renaultsport Brembo kit? Need to replace mine soon
Rallye Race Car
Posted 23rd Jun 2016 at 10:58
Cjwatson27
I was recommended rally design that who I'm getting to do mine. Think ash can get them too
Posted 23rd Jun 2016 at 16:57
anyone that does brake lines, miles, kam racing etc.
Posted 23rd Jun 2016 at 18:22
demondriverdan
Cheers, will speak to them
Rallye Race Car
Posted 23rd Jun 2016 at 19:28
pugheaven
Thinkautomotive are really good and there brake lines are not expensive compared to everything else that sell
Posted 23rd Jun 2016 at 19:33
Cjwatson27
Still struggling here anyone know what length I need and the fittings to get the willwoods to fit standard Peugeot brake lines has everywhere I've tried wants to know this ?
Cheers in advance
Posted 28th Nov 2016 at 18:13
I made the lines for my Alcon calipers with stuff from Torques.co.uk.
you'll need to fit your caliper and work out the hose length yourself, not a big problem for me as the hose comes in units of a metre, so I bought two knowing that a standard hose is 560mm from memory.
make up one hose end and fit them to the caliper or car end, move the strut to full lock each way & droop/bump, make sure you have a nice radius not a taut length.
Posted 28th Nov 2016 at 18:43
Cjwatson27
Cheers I don't fancy attempting to make my own
I might speak to miles
Posted 30th Nov 2016 at 20:53
its a doddle tbh, same as making fuel lines, just smaller stainless fittings instead of aluminium.
Posted 30th Nov 2016 at 21:30
RetroPug
Thread resurrection rather than starting a new one:
The inboard/car end of the braided lines will be 10mm x 1
I'm fitting wilwood calipers, from a very quick measure of the inlet to the caliper it is approximately 10mm and it requires a banjo fitting. 1/8 NPT is only a bit over 10mm so I'm wondering if it could also be this. I'll try winding in a 10mm bolt which should allow me to check whether or not the thread is tapered and should hopefully show it is an M10 banjo!
Just wondering: when others have fitted wilwood calipers did they find it was M10 or a 1/8 NPT?
Posted 22nd Aug 2017 at 20:59
would imagine them to be more like 3/8th unf than a tapered thread if its a banjo.
are thwy used or new?
Posted 22nd Aug 2017 at 21:21
seems wilwood are random and do use 1/8th by 27 tpi, so not somewhere a banjo could be used, you need an adapter then an elbow of your choice
Posted 22nd Aug 2017 at 21:29
RetroPug
They are used.
I have looked and as you said wilwood do use 1/8 NPT on some of their products, but you can also get 10mm caliper inlet fittings from them which would suggest it could be either depending on the product. I'll have to just check with a male M10 union as a starting point I think.
3/8 UNF is another possibility I'll have to consider, good suggestion.
Posted 23rd Aug 2017 at 13:03
RetroPug
The M10 union winds in but only for a bit and then goes tight as it seems to taper. Must be NPT.
Posted 24th Aug 2017 at 21:01
Cjwatson27
I can let you know had mine made but Hel seemed to fit when I dry fitted them together. I was told to steer clear of banjo fittings on a road car
Posted 24th Aug 2017 at 21:46
