Author Subject: Fuel pump priming after shut off
Don't think this has been covered before? For at least the last couple of years after shutting off my 6 the fuel pump primes for about 3 seconds every 30 seconds for about 5 minutes.... then finally stops. Does this every time it's switched off....
Normally they prime once after being shut off which mine does but it continues doing it for some time on and off.
It's never been an issue but just wondering if anyone else's does it or just mine?
I've previously swapped the multifunction relay thinking that would sort it but it made no difference. Must be down to the ECU?
Baring in mind it's a low boost Version 2 mapped ecu do other low boosts do it?
Posted 16th Jun 2016 at 01:21
mocinim
None of mine do just the once then quiet
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 16th Jun 2016 at 08:06
Yup I've owned loads of 6 and rallye and they all do it once. Mine does it like 10x.
Posted 16th Jun 2016 at 08:15
mocinim
Got to be a dodgy relay or like said the ecu
Posted 16th Jun 2016 at 09:02
Robdog Rallye
My low boost does exactly the same and I've also swapped out the fuel pump/ignition relay which didn't change anything either, I'm also using the 2nd revision ecu.
Low boost Rallye
RB182 Cup
Posted 16th Jun 2016 at 09:07
luke306rallye
Mine used to do this when it was standard. Would set my Toad alarm off all the time.
Posted 17th Jun 2016 at 07:46
6waysforward
Mine does it every 60 secs for 5 mins after turn off. Makes it worse as i have a bosch 044 under the boot floor which makes a racket.
My lowboost did it to with revision 2.
Posted 17th Jun 2016 at 09:32
Joka-cro
Did someone sorted out that problem ?
Posted 7th Jun 2026 at 20:12
pug_306
They do that with an unlocked ECU
1992 205 GTi6
205 Turbo 340bhp
Posted 10th Jun 2026 at 09:09
jimmyhackers
i think its a phase 2 and a halfish and onwards thing...
im pretty sure peugeot fitted what was to hand with certain parts....i.e. using leftover/older stock etc.
my phase 1 gti6 never did it.
my phase 1 1.4 xl never did it
my phase 2 gti6 didnt do it.
i currently have a 99/2000 XSI that does do it
and a 97/98 gti6 that does it also.
again, pretty sure this is not an issue.....and more likely a stop gap fix from peugeot for other fueling problems the 306 suffered from.
it is to keep the fuel lines full and primed at all times, as well as the tank swirl pot full....
i imagine this is to prevent them emptying and drying out over time. reducing fuel residue build-up on key components like the fuel pressure regulator.
example of what might happen if it doesn't happen:
my current gti6 had been sitting for 10ish years in a scrap yard,
the non e10 compatible fuel lines on the fuel rail had corroded internally.
im thinking this had blocked/stuck shut the non return valve on the return fuel line to the swirl pot.
meaning my return fuel line was essentially blocked (and bone dry)....
resulting in maximum fuel pressure delivered to my injectors....(bad)
my fuel pump running at max pressure constantly and no fuel circulation so it got hot, eventually killing the fuel pump (bad)
unblocking the return fuel line fixed a lot of other random issues i was having.
so the fuel pump priming randomly isnt reallllly a problem, more a quirk.
only downside is it could drain your battery if you leave the car sat for an extended period of time.
Posted 13th Jun 2026 at 10:12
