Author Subject: Gti6 misfire when warm
shawry-gti-6
Just a question , I have a misfire that clears up when you give it the beans , slow speeds and pulling off it misses ? Any ideas ? Was thinking coilpack may be ??
Cheers Sam
S.SHAW
Posted 12th Jun 2016 at 12:56
Check coil packs and spark plugs first.
Also if it disappears when warm it could be the first signs of HG failure
Posted 12th Jun 2016 at 12:58
shawry-gti-6
Just chenged all the plugs , and yeah going try the coilpacks going try disconnecting them when it's running see what happens , and it's only when it's warm it does it cheers
S.SHAW
Posted 12th Jun 2016 at 13:04
jeffers Forum Admin
Lambda sensor? Coolant temp sensor? (green one)
Team Running Engine again!
Team Negative Camber!
Posted 12th Jun 2016 at 22:05
shawry-gti-6
Cheers mate more ideas the better then if one don't sort it then I'll try another cheers Thumbs up
S.SHAW
Posted 12th Jun 2016 at 22:15
shawry-gti-6
Sorted it , Coil Pack Braking Down When Hot , Runs Like A Dream Now !!
S.SHAW
Posted 15th Jun 2016 at 22:34
woody.
Good stuff, did you just unplug 1 at a time to find out which one was knackered?
Posted 16th Jun 2016 at 21:27
shawry-gti-6
Diidnt Do It On Idle So Much So Got A New Coil ,Kept The Tools In My Car To Do It Every Time I Went Out And It Was Been A Cock I Just Moved It Along One All Sorted Smile
S.SHAW
Posted 16th Jun 2016 at 23:06
