Author Subject: Rebuilding calipers
deeturbo
Hi all,
I was wondering why you shouldn't use silicone grease on new caliper pistons and seals?
I've bought a kit online and they've supplied the two types of grease, one silicone for the slider pins and the other I'm guessing is the red Castrol grease they labeled as hydraulic grease.
I've asked them and their response was "Silicone grease should not be used with piston seals and dust covers as it does not dissolve in brake fluid, where red rubber grease(blue packet) does" but what does it matter if it doesn't dissolve in the fluid?
Posted 7th Jun 2016 at 10:44
mocinim
It can clot up collect additional material and reduce the effectiveness of the piston
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 7th Jun 2016 at 14:54
deeturbo
But wouldn't the other grease do the same?
Posted 7th Jun 2016 at 15:06
barrym
no because it will dissolve
Black Rallye occassional toy
Posted 7th Jun 2016 at 15:58
mocinim
Yea this
Silicon is its own element on the periodic table and doesn't react with most carbon elements and so retains ist form of sorts
Most other greases break down when reacting with other materials chemicals elements stc
Posted 7th Jun 2016 at 16:51
barrym
The only time their instructions may not be relevant is if you were to use DOT5 brake fluid. But you shouldn't be using that anyway
Posted 7th Jun 2016 at 17:10
deeturbo
Ok, Thanks guys.
I know DOT 5 is no good for the ABS pumps in our cars.
I'm going to start using it for karts as some kart systems that I've rebuilt that have had DOT 5 in have no signs of pitted bores or corrosion. Most look like new.
I'll be using DOT 4 in the car and stick with silicone in the sliders and the red stuff on the piston and seals.
Posted 8th Jun 2016 at 10:16
Pitted bores and corrosion is just water in the fluid - you'll still get that with DOT5 - the water might not be miscable with it but it'll get in there just the same and condense in the bottom of the calipers.
Posted 8th Jun 2016 at 11:42
