Author Subject: new injector seals now it won't start
sjsmith
Hi just changed injector seals on my s16 but it now won't fire.there's fuel in lines and fuel rail any help would be grateful.was running nice till I started messing shud there be a prime pump cos I can't see one cheers
Ssmith
Posted 27th May 2016 at 20:53
pull the pipes off the rail and see if you get fuel
Posted 27th May 2016 at 21:36
jeffers Forum Admin
Moved to correct section.
Team Running Engine again!
Team Negative Camber!
Posted 28th May 2016 at 00:10
mocinim
Check your electrics connectors wires etc make sure the metal fins are clean and that you havent pulled a wire out or damaged one
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 28th May 2016 at 04:12
sjsmith
Hi I've got plenty of fuel on larger fuel line smaller one is bone dry.do I have to prime somehow or will it just selfbleed cheers
Ssmith
Posted 28th May 2016 at 07:28
got them the right way round?
Posted 28th May 2016 at 09:41
mechanical_repairs
One is return and one is feed, if the pipes are as standard you shouldnt be able to mix them up, other wise check to make sure they are the right way around as wp says.
Carl
Posted 28th May 2016 at 09:48
sjsmith
All sorted running sweet just double checked everything and changed spark plugs not sure what was wrong but its right now thanks for help cheers
Ssmith
Posted 28th May 2016 at 20:38
