displaying posts 51 to 75 of 130
Pages (6): first .. 2 [3] 4 .. last
Author Subject: SC exhaust help
manthos
Post #51
roland rat wrote:
I'd be looking at the boost pipes before an exhaust if it was me
Why? what would you be looking at?
Team SUPERCHARGED
Old Project thread
Posted 22nd May 2016 at 22:28
Post #52
The bends at the intercooler and into the tb housing.
Posted 23rd May 2016 at 18:32
manthos
Post #53
I mentioned that in a previous thread and it is not an issue on a low boost Rich W confirmed because the pipes are 76mm and the restrictor in the charger on a low boost is 38 so what do you think is more restrictive? ?
Team SUPERCHARGED
Old Project thread
Posted 23rd May 2016 at 18:46
Post #54
Mine are welded right angles at 2.5" all pipework and cooler is what's used for high boost which can achieve 400bhp so don't think it's restrictive at all tbh.
I'd just get the restrictive part removed from the decat and possibly swap the Jetex back box for something straight through unless you're going on track.
Posted 23rd May 2016 at 19:29
Post #55
When it was at the rolling road the guys said it wasn't the best design for flow
Posted 23rd May 2016 at 19:33
manthos
Post #56
and they are correct however because the diameter of the charger restrictor is half the size of the pipes it makes no difference in thus specific case
Team SUPERCHARGED
Old Project thread
Posted 23rd May 2016 at 20:03
Post #57
its not always about how much air, but what it is doing
Posted 23rd May 2016 at 20:14
manthos
Post #58
So what are you saying because Rich has said it's fine
Team SUPERCHARGED
Old Project thread
Posted 23rd May 2016 at 20:27
manthos
Post #59
see post 20
Team SUPERCHARGED
Old Project thread
Posted 23rd May 2016 at 20:30
Post #60
no, i mean exactly what i said!
Posted 23rd May 2016 at 20:37
manthos
Post #61
So please explain to me because I am not as knowledgeable as you.
Team SUPERCHARGED
Old Project thread
Posted 23rd May 2016 at 20:57
Cjwatson27
Post #62
Probably well out of date now but David vizard covers some of this stuff when he explains main idols designs and think there's abit on forces induction. But like I said it's may not be relevant now and for the love of me I can't think of the terms they use
Posted 23rd May 2016 at 21:16
Post #63
vizards book is still as relevant now as it has ever been, as its still a 4 stroke internal combustion engine.
Posted 23rd May 2016 at 21:22
Cjwatson27
Post #64
Good to know. Probably the only book I've read in the last 15 years. Shame he never done one on peugeots
Posted 23rd May 2016 at 21:26
Post #65
manthos wrote:
so what are you saying because Rich has said it's fine
you just have to look at it and imagine what the air is doing in there, then look at any o.e intake system, you wont see angles like that anywhere.
a smaller pipe with a decent mandrel bent curve will be much better.
manthos
Post #66
Yes I agree that's why I created the other thread I posted up here about the pipework I thought logically that there should be curved pipework and not those angles because the air is just hitting a wall but I was told by Rich it's ok and as I am less knowledgable I thought ok.
Team SUPERCHARGED
Old Project thread
Posted 23rd May 2016 at 21:52
manthos
Post #67
However I would like to change the pipework for less bends and nice curved ones too
Team SUPERCHARGED
Old Project thread
Posted 23rd May 2016 at 21:53
rich_w
Post #68
Changing the bends will make f**k all difference on a low boost setup, where the restrictor is substantially smaller (38mm) than the pipework (51 or 63mm).
The resistance or pressure drop across the mitred bends (over and above mandrel bends) is not significant enough to release any significant gains.
If you were putting 600 BHP through the same diameter pipework it probably would have more of an impact. On my old car power was certainly not limited by these bends, and that had nearly twice the power of yours.
The general rule is to keep airspeed below 0.4 mach. A 2" pipe at 0.4 mach would flow 585 CFM at this velocity.
At red line, a low boost 6 would be flowing around 375 CFM. So what I'm saying is there plenty of head room in your setup, and in the real world, changing the bends from a mitred bend to a mandrel won't make any noticeable difference.
If you want some cheaper gains, post me your restrictor ring and £20 and I will machine 0.5mm out of it, that will give you more than any changes to the boost pipe set up for a fraction of the cost! Although you can't go too far or it will run lean.
With our pipework route, you can't fit mandrel bends in either. You can't get the bend radius required. Mandrel bent aluminium generally has a bend radius of 2D, so that's 4" on a 2" pipe. You just can't physically fit them in, we have tried it. You would have to change the pipework route for mandrel bends.
Contact Details:
07732 822546
Posted 24th May 2016 at 00:38
Post #69
why do you need 52mm pipe with a 38mm restrictor?
Posted 24th May 2016 at 05:47
marco gti6
Post #70
0.5mm off the resrictor it is then LOL
You shouldn't have written that mate...
Posted 24th May 2016 at 08:02
manthos
Post #71
I'm so pleased you have come along to this thread with all the knowledge Rich thanks for all your help. I will change the exhaust and see what bhp that gives me and depending on that I may take you up on the offer of maching 0.5mm off the restrictor ring.
Team SUPERCHARGED
Old Project thread
Posted 24th May 2016 at 09:36
cully
Post #72
0.5mm off the diameter or radius Smile
Posted 24th May 2016 at 09:37
Post #73
its not about resistance or pressure drop, but what the air does.
show the pipes to any decent engine builder and they'll cringe
Posted 24th May 2016 at 12:55
rich_w
Post #74
You are missing the point.
Yes, it can be bettered.
I am saying the gains from doing so are tiny on a heavily restricted setup, and from a cost-benefit perspective, it's not worth it.
Hence my comment stating turning out the restrictor 0.5mm will give you more gains than even the smoothest bends, for a fraction of the cost!
Contact Details:
07732 822546
Posted 24th May 2016 at 14:29
rich_w
Post #75
The other thing to consider is what the software has been developed for. It has been developed to work with the bends we have used (love them or hate them!), and it's relatively pointless trying to make miniscule improvements to the efficiency of the system, as the ECU won't put in any more fuel, as at WOT the injection pulse widths are fixed, with the exception of temperature compensations etc. So too much improvement to the air flow will just make it run lean.
If you really want the most from it, open up the restrictor another 2mm or so, and get a custom map from Wayne, and maybe go for 280-290 BHP.
You won't find 40 BHP cheaper than £420!
Contact Details:
07732 822546
Posted 24th May 2016 at 14:53
