displaying posts 26 to 50 of 274
Pages (11): 1 [2] 3 .. last
Author Subject: Wilwood Brackets group buy?
manthos
interesting they can pass the royalty price onto the buyers
Team SUPERCHARGED
Old Project thread
Posted 2nd May 2016 at 21:19
manthos wrote:
Cheers mate. put a link to this on there and see if there is any interest please as I do not have FB
see what the price is for say 10 Pair or if theirs any further discount on say 20 - 25 - 30 etc etc
as soon as I have something solid to report i'll look after the FB side of things add people to list pass on details for payment etc!
just don't want to get people on side then the price be too extortionate to be put into production!
Posted 2nd May 2016 at 21:58
Tarmac terror
roland rat wrote:
Phil means the brackets are his design and he deserves royalties for using said design
To be fair, caliper brackets ain't exactly rocket science and if you gave 10 engineers the task of making one from scratch then you'd probably find that the solution would be pretty much identical...
TT
Posted 3rd May 2016 at 11:19
manthos
Where the f**k did that quote come from I never put that comment
Team SUPERCHARGED
Old Project thread
Posted 2nd May 2016 at 22:59
manthos
I have asked for a price based on 10. I was told the price is made a lot cheaper doing 10 rather than 1 but 20 or 30 wouldn't be much cheaper than 10
Team SUPERCHARGED
Old Project thread
Posted 2nd May 2016 at 23:01
manthos
What I mean is the percentage discount would not go down after 10 apparently unless I assume we went for something like 100 but that's not going to happen. I should have a rough idea of price by the end of the week
Team SUPERCHARGED
Old Project thread
Posted 2nd May 2016 at 23:02
Thumbs up
Posted 2nd May 2016 at 23:27
My guess was that phil meant having all them radius' milled into the brackets would mean they're fairly awkward to copy/machine, as opposed to the more square design from an image I saw of one of welly's first ones.
Posted 2nd May 2016 at 23:47
manthos
in this case Phil do you have a drawing or 3d drawing pdf whatever of the bracket that I could give the company and help folks out on here
Team SUPERCHARGED
Old Project thread
Posted 2nd May 2016 at 23:51
Post #35
As Steve said - the ones you have there are the fancier/lighter version I designed, as opposed to Welly's original square ones - which means a lot more work in milling and setup, so most companies will charge you an arm and a leg as they're not even radii, they're all parabolic curves - I did actually lend Steve a spare bracket so he could get some priced up at one bit but it was stupid money I think.
Posted 3rd May 2016 at 00:11
Tarmac terror
Post #36
Sorted...
apologies Smile
TT
Post #37
Rather than copy it directly, could the 'hard points' like bolt holes and flange faces not be copied ant the bits in between left a little more free form? I know nothing about CNC but surely the dimensions etc should be able to be replicated with a less sophisticated cut file.
Posted 3rd May 2016 at 11:46
Post #38
Yeah, that's what Welly's original was, just square cuts, lot easier to make, albeit a fair bit heavier/less stiff.
edit: Top right
Posted 3rd May 2016 at 12:02
Post #39
Mmmm! Love
Posted 3rd May 2016 at 17:10
Post #40
SHINEY!!!!! Hyper
Come on Phil whats it going to take to get you to redo your Designs rent some machine time
and knock us up another batch?
Posted 4th May 2016 at 08:55
Post #41
I'll cost up, but the problem is they were cheap the first time around because I was doing the design/toolpaths/setting the machine up and running it as well, renting a machine and operator means they'll want to do the toolpaths and then you end up with a bill with some zero's on Razz
Posted 4th May 2016 at 11:08
fast_eddie
Post #42
Do these fit under standard cyclones?
Posted 4th May 2016 at 12:33
Post #43
yes with 10mm Spacers! Wink
Posted 4th May 2016 at 14:19
Post #44
Bugger!
why would you sell your machine! Cry LOL
Posted 4th May 2016 at 14:21
manthos
Post #45
Phillips send me the drawings and I will give them to the chap with the business. He is a customer of mine I might be a able to twist his arm to do a better price
Team SUPERCHARGED
Old Project thread
Posted 4th May 2016 at 15:29
Post #46
Any further with these?
Posted 12th May 2016 at 08:26
manthos
Post #47
Will call them later and find out
Team SUPERCHARGED
Old Project thread
Posted 12th May 2016 at 08:55
Post #48
Thumbs up
Posted 12th May 2016 at 10:57
daver6
Post #49
The brackets that come with the wilwoods from Rallye design... I believe I have these for mine. They fit but you have to run their discs. I'm sure though, if memory serves, they'd need 10mm milled off them to reduce the offset that's set in order to run the RD discs.
Could this be an option? Bulk buy and get them machined?
Wishbone Polybushes available
Posted 15th May 2016 at 15:28
Post #50
with the 285mm rd disc?
never had chance to measure them properly, but they do go under more 15's as theyre much taller offset disc than a 306
Posted 15th May 2016 at 15:41
