Author Subject: Potentially Selling
pugheaven
So as most of you are aware im either stripping the entire dimma or going down the evo engine and running gear route.
If I go down the evo route the following will be for sale...
Dimma front wide track kit.
.Wishbones powder coated black with 2000 mile old ball joints and rich w roller bearing bush's
.dimma drive shafts
.mc phearson top mount plates
.track rod extensions
£1500
-2 degrees camber hubs powder coated black with 2000 mile old skf wheel bearings £220
18x8 revolution millenium wheels with ns2r tyres, wheels and tyres covered 200 miles
£700
Brand new in box 18x8 revolution millenium wheels £500
AP racing 4 pot calipers with 310mm bell and rotors
£1100
Wp pro rear big brake kit 310mm discs and adapter
£250
Custom upper strut brace which hugs the bulkhead
£70
Gaz gold coilovers covered 2000 miles
£450
Rear beam
Full rebuild including all new bearings, seals, trailing arm shafts, every nut bolt and washer (all genuine pug parts with invoice got over £45000 for parts)
30mm ARB
22.5 torsion bars
Baker bm solid mounts
Bridgecraft -3 degrees negative camber
Bridgecraft custom wide track kit
Every part has been powder coated
£750
Phillip m drop links powder coated black covered 2000 miles all the bearings in the rose joints are as new
£70
Phase 1 2.4 vts rack
£150
Quaife diff
£400
Satchshift, as new only 1500 miles
£300
Helix paddle clutch and cover plate (clutch has done 2000 miles since being re plated by Helix)
£100
Super high boost engine with c38 81 charger oil lines 13 row cooler, DTA S60 ecu, custom ecu alloy box, bt Bluetooth adapter for DTA app.
Bottom end got rebuilt 2000 miles ago by rich with lots off new parts and invoice showing over £500
Loads of power coated, plated and anodized parts
All ways run on royal purple oil.
Spoox blue silicon oil and water hose kits
Engine loom and all associated parts
Can be seen running, any checks can be done before purchase (compression test etc)
Running 446 hp before the restrictor was opened up
£5000 which is less than half the price it costs (invoices to prove)
Gti6 exhaust manifold ceramic coated in grey £350
Custom Torque techniques 3" centre exit manifold back system only covered 1400 miles max
Entire system is heat wrapped, water repellent sprayed
£650
KAD straight cut 3rd and 4th gears set? Will get miles to remove them from the box and inspected
2000 miles use, always used the clutch
£700 ono
Metal exhaust manifold heat shield powder coated black (not the new style ones that Ryan is selling, this one is one of the ones Simon had made, compare the two and make your own decision on which ones better)
£60
Custom 6 point bolt in roll cage (will require box sections welding in for the feet to bolt to) with double door bars and rear legs going to beam mounts, powder coated black
£600
Vibratechnics race top engine mount,gearbox mount, solid rear mount 2000 miles use
£200
Iv had loads of messages requesting for parts but for ease can ppl post on here what you would want
Posted 23rd Apr 2016 at 19:00
Good luck Ollie Thumbs up
Posted 23rd Apr 2016 at 19:30
jorg
any pictures of the custom upper strut brace? maybe interested Hmm
306 2.1 S16 Tarmac Rally Car
Posted 23rd Apr 2016 at 19:32
barrym
Sad to see this but first dibs on the Quaife diff please
Black Rallye occassional toy
Posted 23rd Apr 2016 at 19:33
pugheaven
Should be pics of the strut brace on my project thread bud.
Posted 23rd Apr 2016 at 19:51
fatlapit
Ill dibs rear brakes on here too lol
Posted 23rd Apr 2016 at 19:58
jorg
yep you are right there are loads of pics of it Doh
Posted 23rd Apr 2016 at 20:04
pugheaven
Lol I'm not with the car or I would have made it easier for you instead of searching for a pic
Posted 23rd Apr 2016 at 20:05
jorg
its in pretty much every picture of the engine bay, don't know how i never spotted it before LOL
Posted 23rd Apr 2016 at 20:07
6waysforward
Does the helix clutch come with a helix cover to or a standard one?
If its all helix, 1st dibs on that LOL
Oh and 2nd dibs on the diff of barry does not have it.
Posted 23rd Apr 2016 at 20:40
pugheaven
Think it's a Sach cover as that's what most people run with Helix clutch
Posted 23rd Apr 2016 at 20:48
cj-gti6
Dibs;
Dimma front wide track wide & -2 degree hubs
Rear wide track beam
VTS rack
AP brakes
TT custom centre exit exhaust
Vibratechnics mounts X 3
99/S Carbon Gti-5
Posted 23rd Apr 2016 at 22:50
Cjwatson27
Coil overs and shatchshift I'm backwards and forwards to Portsmouth at the mo if it comes to it which I hope
It doesn't 😞
Posted 23rd Apr 2016 at 23:25
3rd time lucky
2nd dibs on the coilovers and diff please Smile
BLACK RALLYE - Sold
CHERRY RALLYE - new toy
Posted 23rd Apr 2016 at 23:44
6waysforward
Thats what i have already but it occasionally slips on vigorous gear changes Sad
Posted 24th Apr 2016 at 00:17
superchargedblack1997gti6
Ollie do I still have the bits we spoke about available?
Posted 24th Apr 2016 at 08:51
pugheaven
It's never slipped on me, depends on how good your fly wheel is too I guess
Posted 24th Apr 2016 at 09:35
cj-gti6
I'll have the strut brace as well if jorg doesn't take it.
99/S Carbon Gti-5
Posted 24th Apr 2016 at 11:54
jorg
all yours mate, I can't make it fit Sad
Posted 24th Apr 2016 at 12:30
3rd time lucky
Re: rear beam. I know it has dibs on it, but will need to be modified to run normal width? Also, £45000 is a lot for a rebuild! Lol
BLACK RALLYE - Sold
Posted 24th Apr 2016 at 12:32
pugheaven
Lol yup £45000 is a lot £450 isn't.... God knows how I didn't notice those extra 00.....
Yup it's only good for wide track and the potential buyers know this Thumbs up up
Posted 24th Apr 2016 at 12:44
cj-gti6
How do you know that?
99/S Carbon Gti-5
Posted 26th Apr 2016 at 16:47
ad
2nd dibs on the vts rack please, been looking for one for ages.
Posted 26th Apr 2016 at 18:06
jorg
nothing to do with the strut brace. Issues with top mounts and things in way by the bulkhead
Posted 26th Apr 2016 at 18:40
cj-gti6
Thumbs up
99/S Carbon Gti-5
Posted 26th Apr 2016 at 18:47
