Just got to get hold of it first...
"Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6
2000 (X), Moonstone
| Author | Subject: misfire |
stan_306gti6
Post #76
£80 mate and I'll deliver it to you.Just got to get hold of it first... ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
aaron6
Post #77
Okay fella. Ta very much. I'll let you know on it as do have the unknown spare and to be fair, I drove it last night and it was absolutely flying with the decat and de-resonated inlet manifold, newer injectors and coils and and a huge array of sensors and an ecu. ![]() Is there a way to lock a soft unlocked to my car? ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
stan_306gti6
Post #78
If it's soft unlocked it should lock to your car once you switch it off...then to unlock it again you will need to cut power to it after you've gone two clicks on the ignition.________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
pug_306
Seasoned Pro Location: Great Hockham Registered: 28 May 2013 Posts: 1,597 Status: Offline |
Post #79
I dont think it will lock to his car. It will just lock and wont start the car again. You need to leave transponder unplugged________________________________________ 1998 Supercharged White Rallye1992 205 GTi6 205 Turbo 340bhp |
aaron6
Post #80
Ah that's what I'd heard Ryan. I might invest in an unlocked one if I see one cheap enough. ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
stan_306gti6
Post #81
Any progress on this Aaron? ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
aaron6
Post #82
Yes mate. Just running to check it stays okay. We used the soft unlocked ecu and another set of coils and the problem was sorted. Put the old ecu in lastnight and it seems perfect. In fact, better than perfect. It f**king flies for a standard one now. And the the noise we always thought was a lazy lifter when cold appears to have gone too. ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
stan_306gti6
Post #83
Interesting.I'm glad you've made some progress, most likely your original ECU suffered from water after the jetwashing. Pretty unlucky for that to happen though. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
aaron6
Post #84
That's the thing, we refitted the old ecu and it's fine. Very odd.________________________________________ See the sheer power and might of the lesser known burrowing owl. |
stan_306gti6
Post #85
It may have had a drop of water in it and by removing the ECU it has been dislodged and now the unit functions as normal.Glad it appears to be resolved anyhow. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
aaron6
Post #86
Maybe. Who knows. ![]() Seems alright now and as I say, it flies with all new or lower mileage bits and the few other little mods we did along the way. ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
Post #87
Changing the ecu never cured anything so I don't think it was the problem. The first time it ever ran nicely for a couple of hours was after I cleaned up all the earth's and added an extra one to the head. It then ran fine until Aaron collected it and it then misfired again on and off causing backfires etc. I think it was the fact the loom and the arts got wet that started the initial problems with the earth's on the gearbox / wing then there was another sensor and a coil that weren't happy after it had misfired a lot and not burned a load of fuel. (Also destroyed the cat) The ecu was bone dry however there was an oily residue on the pins but that didn't seem to be affecting anything and may have been there for years. It would then run fine for a while then a dodgy coil would mess about. God knows though tbh we changed just about everything and cleaned up everything so could have been anything really. ________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
aaron6
Post #88
Either way the f**ker is working now.________________________________________ See the sheer power and might of the lesser known burrowing owl. |
stan_306gti6
Post #89
As you say Pete, it was probably a whole host of things which snowballed from a relatively simple fault to begin with.Glad it's fixed though, was a head scratcher... ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
aaron6
-er-
Junior User Location: Istanbul / Bodrum Registered: 20 Sep 2007 Posts: 77 Status: Offline |
Post #91
What a ridiculous problem. I think my problem is the ECU and I had done a jet wash before I had this problem.I removed all the sensors and cleaned all the grounding points. All the fuses and all the relays were changed or measured with a multimeter, but the multifunctional relay still does not work as it should. It all started like this https://youtube.com/shorts/cqq7CLdzni8 https://youtube.com/shorts/ovz7hmaeBLY https://youtube.com/shorts/KaQtlCmI52Y https://youtube.com/shorts/PgC2zq-WKX4 https://youtube.com/shorts/bHYEy4CvotI https://youtube.com/shorts/i9skIsI4sFs https://youtube.com/shorts/cAS0V_2Bfk4 https://youtube.com/shorts/AEuz6d66TGw https://youtube.com/shorts/JSarE_em4ac https://youtube.com/shorts/YZDMWjiG-q4 https://youtube.com/shorts/gbgd8yQ2wm0 https://youtube.com/shorts/prHFKbfgoec https://youtube.com/shorts/CMW5TcBGf5I I will continue to try and make videos. ________________________________________ My Channel ERELPeugeot 306 GTi-6 N5 / PH2 / Diablo Red / Mustang Red Cloth (Sold )Peugeot 306 GTi-6 N5 / PH3 / Diablo Red / Alcantara Suede Peugeot 306 GTi-6 N5 / PH2 / Bianca (Sold ) |
jimmyhackers
Seasoned Pro Location: birmingham Registered: 14 Jun 2011 Posts: 1,302 Status: Offline |
Post #92
high octane fuel and the gti6 do not mix.....octane is not the power it has it is its resistance to pre-detonation!!!!! ergo high octane fuels in the gti6 can resist combustion leading to misfires. ________________________________________ the world is changed by people in sheds |
