Author Subject: Idle Control valve Problems
My ICV started to give various problems such as low idle, hunting, etc. I cleaned it and it now just idles low.
I cleaned a spare and fitted but that just idles at 3.5K until I blip the throttle. it then hunts between 1-2k.
Both resistances test correctly. Do you think I should try to clean ultrasonically using alcohol?
Posted 22nd Mar 2016 at 23:08
mocinim
No reset the ecu after fitting the new one its not uncommon for the icv to idle incorrectly after fitting until correctly reset
Unplugging the battery and reconnecting is not a reset cant remember the sequence atm but its fairly easily available
Smile if you can get it plugged in for a full system reset is the best way but not essential
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 22nd Mar 2016 at 23:16
I did a full ECU reset twice, once with each cleaned ICV.
Posted 22nd Mar 2016 at 23:40
marco gti6
Did you leave the battery disconnected for at least 15 minutes?
Posted 23rd Mar 2016 at 07:28
cleaning never does much tbh, just fit a new one.
Posted 23rd Mar 2016 at 07:59
Yes, left it disconnected while I removed, cleaned and refitted it.
Posted 23rd Mar 2016 at 08:27
mocinim
A new one it is then bud
Best to use a magnetti chap
Posted 23rd Mar 2016 at 09:05
jeffers Forum Admin
As welshpug says, save urself the heartache and buy a new one, even if it works ok after cleaning it will fail soon.
Team Running Engine again!
Team Negative Camber!
Posted 23rd Mar 2016 at 12:19
I cleaned it ultrasonically and the revs still rise to 4000 and only lower when I blip the throttle resulting in it hunting between 1-2k. I got a new one from GSF and that does the same too. Strangely, unplugging any injector also makes the revs rise to 4k.
Posted 25th Mar 2016 at 23:20
cully
check the butterfly is not loose on the spindle
Posted 26th Mar 2016 at 00:07
