Author Subject: Fans not working.
Well.
They haven't worked properly for a very long time.
But i was running them pikey style with the ac switch and bridged pins 1+3
However after about 4 years that has stopped working. I bave re done the cable bridging.
No luck.
I assume there is something more fundemental going on.
Neither fans work when the ac switch is on. And the dont work when i pull the temperature sensors either.
Where should i begin?
Posted 13th Mar 2016 at 15:00
mocinim
Relays in the front cowling two green one black start with the black one Smile
Behind the front center plastic just remove it triangular box underneath
Careful on removal the clips will snap two screw holes can be drilled in the obvious spot in the cover to resecure
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 13th Mar 2016 at 15:13
Where can you get new ones. I remember peugeot wanting 80 for all 3.....
Posted 13th Mar 2016 at 15:10
mocinim
Ebay 7 bucks each or ryan _ pug 306 there quite common
Posted 13th Mar 2016 at 15:15
Are all peugeot ones the same?
Posted 13th Mar 2016 at 15:55
no, pull them out and check what type you need, switching 5 pin or on-off 4 pin, maplins and the like do them cheap.
Posted 13th Mar 2016 at 15:57
You're back! Shock
And I bet you still haven't fitted the suspension or supercharger kit Laugh my ass off
Posted 13th Mar 2016 at 16:24
cully
check the fans actualy work
check the fuses to there are many that control the fans
Posted 13th Mar 2016 at 16:57
heliosphan
I had intermittant to non-functioning fans for a long time and eventually found that it was a very poor connection at the rear of one motor. As said, check they actually work with 12v at the terminals first. They're exposed to road salt and water because they're in front of the rad-pack, instead of behind it as on most other cars.
Posted 13th Mar 2016 at 17:36
My car was particularly salted the other day after it rained and I did a run up the m4
Posted 14th Mar 2016 at 00:35
