Author Subject: Brans Hatch Drive By DB Test
ravemercer
I've tried calling the noise info department they never pick up so can anyone tell me details about the noise testing they do at brands hatch getting the 6 ready for track day wanted to replicate the test to make sure its within regs as static is close.
I've tested the 6 static at 101db Shock @ 5650rpm 0.5m @ 45 degrees from exhaust.
The regs says 20m drive by but what full chat or cruzing ?
Posted 11th Mar 2016 at 16:33
Chr1sch
Bloody hell - 101 static is LOUD! although you would expect lower on drive by at distance
My magnex with a cat is 89 static, and didnt trip anything at Bedford (or anywhere near) and they are notoriously tight
Posted 11th Mar 2016 at 16:43
ravemercer
it's a nice kinda loud Smile its high boost with a a decat straight through mid 2 1/4 and remus backbox so its fairly quiet on the mway @ 60 mph tbh just peaky when reved.
Posted 11th Mar 2016 at 16:53
demondriverdan
They have microphones at several places around the circuit and will measure your noise as you go past regardless of whether you're at full chat or cruising.
My car is around 95db static but trips the drive by sometimes due to the throttle bodies and exhaust popping. If you trip it you get 1 attempt to fix the car, if you trip it a second you're not allowed back out on track again. You can buy extra silencers / plates that go on the end of the exhaust to bring the noise down
Rallye Race Car
Posted 11th Mar 2016 at 17:03
ravemercer
Ok cheers ill test it at different rpms then. I will be getting a exhaust made up soon so will see what db its producing at 20m first then decide if I'm going to stick in another box in the mid section.
Posted 11th Mar 2016 at 17:20
demondriverdan
Static testing is fine but it's different when the car is under load or you're actually driving it. I have no problem with the static noise tests but when I heel and toe down it can trip the drive by limit.
If you are worried I would pick up an extra exhaust silencer before going to the trackday, something like this: https://www.merlinmotorsport.co.uk/p/merlin-mild-steel-racing-muffler-m-ex-muff-4
If you have no problems on the day you can always return it but I'm sure you'd prefer to have a backup option if you do have issues.
I've learnt to do a bit of lift and coast at certain points of the track to help the noise out Big grin
Rallye Race Car
Posted 11th Mar 2016 at 17:26
ravemercer
Ok thanks for the sound advice. Ill replicate the conditions best I can actually driving past in a suitable location at 20m I've got a cheap sound tester it's fairly accurate.
If I'm close to 92db ill defiantly be putting a midbox on. I've almost made my mind up of the exhaust setup now I will be putting in a fia 100 cell jettex sports cat so will reduce the noise with that.
Is there a certain point in the revs you would say it reaches its peak sound 5500rpm etc or would you say higher the revs higher sound all the way to 7500 ?
Posted 11th Mar 2016 at 18:15
RetroPug
Removing the midbox on most stainless systems doesn't seem to increase the overall volume too much, but it does significantly increase the booming reasonance that you tend to get around 3000rpm or so, which does significantly increase volume at that point.
The volume at idle and under most driving conditions seems to be almost entirely affected by the rear silencer on a standard engine from my experience.
Posted 11th Mar 2016 at 18:55
is your name stan too? LOL
Posted 11th Mar 2016 at 19:21
aaron6
3k revs on track? Don't think mine went below 5k at brandshatch. LOL
Posted 11th Mar 2016 at 19:45
ravemercer
ha ha no its dave isn't his like 130+ that's a whole another level of noise I just like the sound don't want to reduce flow and make it quite. I know there's a balance but I don't mind being on the 100 db side of it Big grin
On the back box side the remus is a reverse flow/chamber like the o.e so it does a good job keeping it quiet at lows revs until its booted it's more restrictive than a absorption type box hence I don't want really want a mid pipe on.
Posted 11th Mar 2016 at 19:59
RetroPug
Of course not 3k revs on track.
I'm just discussing what resonance the midbox in the std. system typically eliminates, and what the effect of removing it would be. Which is basically lots of boom but only at very specific places in the rev range, and a nice change in tone everywhere else. I can't remember specifically what rpm this occurs at but typically 40mph in 6th, especially under load.
How is the remus? I've always wanted to try one out. I have a scorpion rear silencer at the moment which seems to be pretty much straight through with some perforated/baffled tubing.
Posted 11th Mar 2016 at 21:17
fatlapit
Flowmaster boxes ftw if your stuck. A box is no good if you can see through it.
Posted 11th Mar 2016 at 21:28
132dB for me as a static test - with Devil Decat, bespoke straight through centre section and Magnex 4" back box...it works for me...Devil
Posted 11th Mar 2016 at 22:15
ravemercer
did you used zero exhausts to make your pipe ?
Posted 12th Mar 2016 at 08:50
I most certainly did sir, couldn't recommend enough. Cool
Posted 12th Mar 2016 at 10:07
I wouldn't, they royally f**ked yours up!!!
Posted 12th Mar 2016 at 17:30
Would only be a static test as it never goes anywhere Laugh my ass off
Posted 12th Mar 2016 at 19:22
ravemercer
Will be paying him a visit next couple weeks last time I spoke to him was booked up for months .
Did he mandrel bend and flair your pipe no cutting and welding ? Does it resonate atall being straight through ?
Posted 14th Mar 2016 at 10:48
Hardly, I asked for a pipe to be made the exact same as my Magnex centre section but without the box.
I knew it would be noisy and it is. Job completed all for under £100 too.
Meirion your extensive knowledge on here is invaluable but there's no need for your constant sarcasticness...Zzz
Posted 14th Mar 2016 at 15:43
He did indeed mandrel bend it. No flaring as mine is a sleeve fitment.
It resonates a bit, makes the exhaust pop and bang on the overrun and is generally very loud.
Just what I wanted to be honest as not interested in track these days.
And Roland, I'll have you know the car does get driven, as recently as January this year. Will also be taken abroad later this year too. Yes
Posted 14th Mar 2016 at 15:46
your exhaust puts the whole 306 world to disrepute, I don't understand how someone can think that 131 db is cool, respectable, its plain downright rude and antisocial.
Posted 14th Mar 2016 at 16:13
It's that noisy at a static test though at 3/4 revs, it's not that loud at idle or low rpm when it's being used.
Yes, start using the loud pedal rather hard and it is extremely noisy - but there's a time and a place and I'm always respectful of that.
Posted 14th Mar 2016 at 16:17
ravemercer
Ok good when I've got the midpipe on we could meet up outside a retirement home @12am we can find out who's is louder see if we can rattle some teeth loose. :O
Posted 15th Mar 2016 at 10:01
