Author Subject: Engine loom
ravemercer
After a decent condition engine loom delivered
Posted 10th Mar 2016 at 18:34
jeffers Forum Admin
What phase?
Team Running Engine again!
Team Negative Camber!
Posted 10th Mar 2016 at 21:03
RetroPug
I have a working ph.1 one for sale.
Posted 10th Mar 2016 at 21:56
ravemercer
Phase 2 but I'm willing to swap over plugs on the phase 2 to 3 just the map sensor iirc ?
Never seen a phase 1 any thing different to the 2?
Posted 11th Mar 2016 at 10:09
ravemercer
Just looked into phase 1 seems there might be a different on the multi plug side so don't want to mess with that side
So ph2 and 3 cheers
Posted 11th Mar 2016 at 10:44
jeffers Forum Admin
Best bet is put a picture of the map connector up as iirc it's phase 3 that's different one and two have the older type connectors. What year is the car?
Posted 11th Mar 2016 at 13:39
cully
PH2-3 engine loom differences
MAP sensor
1920 9H <RPO 08056
1920 AN >RPO 08057
oil pressure switch
1131 82 UNTIL RPO No. 07874
1131 C5 SINCE RPO No. 07875
PAS sensor
4015 02 UNTIL RPO No. 08036
4015 08 SINCE RPO No. 08037
gearbox reverse switch
2257 41 UNTIL RPO No. 08420
2257 59 SINCE RPO No. 08421
Posted 11th Mar 2016 at 14:50
ravemercer
Cars a 98 it's got the old type connector for map I'm up for phase 3 loom as well. I will just swap over the plugs if need be as some are going to be extended as I've sc engine also I've modified the pas to electric under boot so pas sensor has been moved. I'm going to by a new map sensor so ph3 loom would be preferred as sensors are coming up fair amount cheaper.
Cully thanks could come in handy when buying new sensors .
Posted 11th Mar 2016 at 15:29
demondriverdan
I've got a loom out of the Rallye you could have, I think it should work with a Ph2
Rallye Race Car
Posted 11th Mar 2016 at 15:39
ravemercer
Thanks Dan are you about the weekend, your from kent iirc ?
Posted 11th Mar 2016 at 16:23
demondriverdan
I'm not around this weekend as I'm testing the race car. I should be free next weekend though.
Yes I'm in Kent
Rallye Race Car
Posted 11th Mar 2016 at 17:28
