Author Subject: xsara stalling.
devere
Not quite a gti6 or rallye. But we can consider I similar...
Got a xsara picasso 1.8 16v. It has a tendency to stall itself, and just be a little 'fluffy' if that makes sense sometimes.
It's OK when it's going and your driving along, but it's more when slowing down, and then going to put your foot down again.
It just had a service for the first time in 3 years.... and I wasn't sure if it was more coincidence or something has happened. It has had an engine management light on for a while, although I'm not sure what the code is at the moment... Doesn't help the cause, but as said has only just started getting worse since the service etc.
Posted 2nd Mar 2016 at 10:26
late ones are FBW, so probably that.
but get it on Lexia and go for a drive, you'll soon find what it is.
Posted 2nd Mar 2016 at 10:37
devere
Am I missing something with FBW?
It's a 2002 car so not overly old, assuming an earlier one?
Posted 2nd Mar 2016 at 10:42
devere
fly by wire throttle?
Posted 2nd Mar 2016 at 10:44
cully
Fly By Wire
Posted 2nd Mar 2016 at 10:45
devere
I should have twigged!
Is it possible either maf tps could be at fault assuming it isn't a fly by wire job? Or is 2002 late enough to possibly be on there? Just looking at the easy things to unplug and try before having to look for a planet laptop.
Posted 2nd Mar 2016 at 11:10
they dont have a MAF.
Posted 2nd Mar 2016 at 11:36
devere
Ah right! Any others to try just for trying to narrow it down?
Posted 2nd Mar 2016 at 13:09
mocinim
Did you change the fuel filter ?
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 2nd Mar 2016 at 13:13
devere
All filters changed including fuel filter.
Posted 2nd Mar 2016 at 13:23
mocinim
Did you change yourself correct one used etc spark plugs thinking the same maybe
Guessing you had no issues at all before except the kight being on
Posted 2nd Mar 2016 at 13:34
devere
Yeh I changed it. Like for like replacements. Albeit different makes. Everything seemed correct and everything went together fine. I'd not really driven the car much but I assume it is something just seeming to get a bit worse.
Posted 2nd Mar 2016 at 13:39
mocinim
Would say fuel management at a guess but could as easily be airflow does it have icv
Posted 2nd Mar 2016 at 16:08
mocinim
Just a thought when you get it running again is it rich or smokey fumes
Posted 2nd Mar 2016 at 17:45
devere
From what I know it runs fine. Just seems like it's wanting to stall. Presumably when stopping.
I was think icv myself but haven't been able to check anything.
I assume if it has an icv, if I unplug it, it should prove a fault or not maybe?
Posted 2nd Mar 2016 at 18:04
mocinim
How many lambda sensors bud
Posted 2nd Mar 2016 at 18:18
will be two on this, it's an ew7.
Posted 2nd Mar 2016 at 18:32
mocinim
Thought this ^
Id be checking these also
Posted 2nd Mar 2016 at 18:34
devere
Yeh I was half thinking they were a possibility. There was a loose heat shield underneath that had been rattling around on top of the lambda sensor and wire. So thought it may have done something to the wires.
Will have to get it plugged in tomorrow. Just hoping for a starting point t.
Posted 2nd Mar 2016 at 18:39
