Author Subject: Yamaha R6 throttle bodies + MS ECU.
As above, selling my R6 'bodies, had originally intended to use these on my TU3 engine but now I have a V6 I don't think 4 throttle bodies will work very well Wink
They're from a 2005 model R6, 38mm diameter (so you should be good up to 180-200bhp or so), and they have built in constant velocity sliders like a CV carb, which keeps the airspeed up over the injectors at lower rpms, or with smaller engines, so you get better bottom end torque/mpg/emissions.
They come with the injectors (updated 4 hole spray pattern versions), fuel pressure regulator, the throttle position sensor, MAP sensor, and all the wiring plugs to connect to them, they also have a remote idle speed adjustment cable that you can pop somewhere easy to get to for fine tuning, the fast idle valve is there too.
Condition-wise they're perfect, they only did delivery milage to the dealer in Louth that I bought them from - where they were removed as the bike was to be converted for racing. There's not a mark or spec of dirt on them, they've been wrapped up and dry stored since.
£75
Pictures to follow.
Posted 24th Feb 2016 at 12:41
Ashjackson
Really interested m8
Posted 18th Feb 2016 at 00:03
Pics:
And as mentioned I have the other half of the connectors/wiring tails for TPS, injectors, etc.
Posted 22nd Feb 2016 at 21:49
Ashjackson
What's the price m8
Posted 23rd Feb 2016 at 12:29
phillipm wrote:
£75
Smile
Posted 23rd Feb 2016 at 12:47
Ashjackson
How much extra posted??
Posted 23rd Feb 2016 at 16:54
Be ~£6 for 3-5 day or £10 for next day delivery.
Posted 23rd Feb 2016 at 17:28
Ashjackson
Pm sent
Posted 23rd Feb 2016 at 17:59
Sold pending payment Smile
Posted 23rd Feb 2016 at 18:25
Ashjackson
Thanks m8
Posted 23rd Feb 2016 at 18:34
Will be selling the Megasquirt ECU I was going to run these on shortly too, MS1 v3 with Squirt 'n' Spark firmware so it can do fuel and ignition, was just in the middle of converting it to use the wasted spark coilpack from the TU engines (have one that can go with it - will finish and test the conversion before it goes, obviously!).
Comes with a Megastim simulator board so you can bench test it all with various inputs, etc, and it also comes with a new ECU loom connector so you can build your loom straight to it rather than splicing into wiring, and the cable for PC connection.
I can get a video of it running on the bench through the simulator if anyone wants - but it's brand new and basically never been used bar bench testing it.
£200 takes it.
Posted 24th Feb 2016 at 12:55
potpot
Looks and sounds awsome, would love it if i could fit these in my rallye only trouble being i wouldn't have a clue what im doing!
Posted 24th Feb 2016 at 17:54
Ashjackson
Have you got some pictures of the mega squirt m8
Posted 25th Feb 2016 at 10:51
Potpot I'm in the same boat! LOL
Posted 25th Feb 2016 at 13:17
Piccy's:
The stimulator/testing board has been modified so it can simulate wideband as well as normal lambda sensors too.
I can get a video of it powered up and running if need be.
Although now I'm getting tempted to just keep it and upgrade to MS3 and run the V6 on it LOL
Posted 25th Feb 2016 at 18:12
IvayloPavlov
You can run with this V6 as well. Only one more inj & ign driver is needed.Mine MS2v3 is with external pair of S16 ignitor because of wasted COP mode. Unfortunately a lot a of modification need to be done to go sequential mode. How much delivered to Guildford Surrey GU1 1RU?
Posted 25th Feb 2016 at 18:32
I think it'd be about £10 for insured delivery.
Posted 25th Feb 2016 at 19:04
'bodies sold, ECU still for sale.
Posted 26th Feb 2016 at 16:57
