displaying posts 2201 to 2225 of 3423
Pages (137): first .. 88 [89] 90 .. last
Post #2201
whens it getting numbers on the doors Damien?
Big grin
Posted 22nd Feb 2019 at 21:22
Post #2202
quote:
[quote="welshpug!"]whens it getting numbers on the doors Damien?
Big grin
Blimey Hello Stranger Thumbs up
Your so so right meirion.....I’m also thinking....it’s going to be such a shame when finished not to race it .....
Any suggestions what I could race it in though ?
Lots of the stuff ....doors etc exempt it from lots of classes ...Thumbs down
I’ve got to do another full loom strip inside the car and possibly fit similar Cartex centre console setup same / similar to Ryan Eninion?
Mines still working off the original key ..
Spoke to Sandy yesterday and he can modify his engine loom easy to come inside off the keypad rather than it is now going into the original inner wing loom ...
That’s the next job ....
I no longer use anything off the standard dash ...other than indicators or lights /high beam ...even speedos going GPS
Posted 23rd Feb 2019 at 06:53
blandy
Post #2203
Thing the i coudl think off is time attack?
Or combe Gt's?
You going to stick with 306 clocks or go aftermarket?
Posted 23rd Feb 2019 at 11:02
Post #2204
quote:
[quote="blandy"]Thing the i coudl think off is time attack?
Or combe Gt's?
My Clocks aren’t really used any longer Mike ...apart from info of indicators and head light beam ...I have all individual clocks for there info nowThumbs up
Silly me buying something like a £1400 DTA GPS dash or something cheaper now .....I have all the same info I need on Stack separate clocks and now that I don’t use my standard clocks anymore I may just blank it after my rewire and put a GPS speedo / timer in its place ....
100% it would of been easier going digital dash and cheaper but I’m where I’m at now LOL
I do like the separate clocks though and my stack ones are the pro digital ones that you set up and change colour if there’s a problem and they hold the info even when turned of .
Posted 24th Feb 2019 at 00:40
Post #2205
Small update
Done ...
New 4way Suspension fitted .
Brake callipers and Discs fitted.
Pedal box and Front brakes bled .
Still to do ...
Fit new flywheel and flywheel bolts .
Fit new twin clutch .
Fit Sequencial gearbox .
Fit hydraulic clutch and Dry brake line .
Fit 4way remote canisters
Fit new driveshafts
Posted 4th Jun 2020 at 19:00
Post #2206
Those brakes!!!!
Posted 26th Feb 2019 at 20:37
Post #2207
quote:
[quote="hovis16"]Those brakes!!!!
LOL
I do laugh when I see them Marcellus ....360mm
I’m hoping with my Servo removed and my brake Cooling ducts blocked I’ll be able to get them warm enough to bed in let alone use and abuse ....Castle Combe on shake down /test day this Jan was bitter cold and I couldn’t get them hot enough to work 100%...I’m going to now try and block the front bumper brake cooling ducts as I’ve already said and see what happens Thumbs up
Posted 28th Feb 2019 at 11:02
Post #2208
New Flywheel and new Gen Peougeot bolts fitted and torqued to 50nm .
Clutch going on tomorrow...
Posted 4th Jun 2020 at 18:59
Post #2209
Hopefully they rip your face off Smile
Posted 2nd Mar 2019 at 08:45
Post #2210
quote:
[quote="hovis16"]Hopefully they rip your face off Smile
Hopefully LOL
Posted 2nd Mar 2019 at 09:36
Post #2211
Clutch fitted and torqued up and the alignment tool was a godsend Thumbs up
Posted 4th Jun 2020 at 18:58
blandy
Post #2212
Be flying round in no time
Posted 2nd Mar 2019 at 17:38
blandy
Post #2213
quote:
[quote="Day666"]Alloy plate made and stuck onto my nearside rear quarter Lexan window at the point I fill up ....any spills with VMAX petrol tend to melt the Lexan and mark it ....learned this from the race cars I helped out the last couple of years LOL
Where did you get your surround from? After killing a window with a fuel leak thinking it may be a good idea lol
Posted 2nd Mar 2019 at 18:43
Post #2214
quote:
[quote="blandy"]
Do you mean ....Alloy surround on my rear Quarter...around filler cap ?
I made it from 2mm Alloy and used silicon to bond it on Thumbs up
Posted 2nd Mar 2019 at 18:59
blandy
Post #2215
Sorry yeah thought it would of quoted the pic to
Posted 2nd Mar 2019 at 19:24
Post #2216
quote:
[quote="blandy"]Sorry yeah thought it would of quoted the pic to
I’ll post the pic again
Posted 3rd Mar 2019 at 16:11
Post #2217
Yet another small update
Sorting out my throttle and linkage today ....simple cable and it can be replaced in minutes if need be ....
Support Bracket made inside made of alloy then bent and used expoxy resin to support and strengthen corners ...then painted used a old Shimano brake cable adjuster inside the car and also have one by the Jenvey linkage under the bonnet
Set everything so Jenvey are fully open and pedal stops not to put any unwanted pressure on the cable ..
The cable is a Shimano MTB cable with the PTFE liner so super smooth.
Posted 4th Jun 2020 at 19:01
Post #2218
Posted 4th Jun 2020 at 19:03
Post #2219
Posted 4th Jun 2020 at 19:05
Post #2220
Post #2221
Posted 4th Jun 2020 at 19:06
Post #2222
Posted 4th Jun 2020 at 19:09
Post #2223
Posted 4th Jun 2020 at 19:10
Post #2224
Just keep a regular eye on the throttle cable. I used one from a bike on mine and over time it frayed until one day when it snapped and jammed the throttle wide open. Not ideal half way round Schwedenkreuz on the Nurburgring! Doh Laugh
Posted 3rd Mar 2019 at 19:39
Post #2225
quote:
[quote="prism7guy"]Just keep a regular eye on the throttle cable. I used one from a bike on mine and over time it frayed until one day when it snapped and jammed the throttle wide open. Not ideal half way round Schwedenkreuz on the Nurburgring! Doh Laugh
...I’m Aways on watch Thumbs up
Posted 4th Mar 2019 at 19:19
