displaying posts 2151 to 2175 of 3423
Pages (137): first .. 86 [87] 88 .. last
Post #2151
Small update
Gone and upgraded my front (Black art design) Suspension to 4way remote under bonnet canisters ...so needed some clamps to hold them and being 48mm found these little alloy beauties which are hinged Thumbs up
PS ...I’m removing both the top black alloy thumbscrew and bottom butterfly thumbscrew and cutting down the thread and using nylock bolt instead ....then fitting these to under bonnet inside wing panel .
Posted 12th Jan 2019 at 04:59
Post #2152
Small update ...
Big thank you to (Tony Palfrey) of Maxi Motorsport / Satchell fame for sorting out my TTV twin (compact) clutch with Sandy recommended Low kg pressure plate made for Maxi Motorsport
Sandy says you shouldn’t use his KG pressure plates on single or twin clutch’s on his engines because of the loads it puts on the thrust bearings?
Posted 25th Jan 2019 at 20:17
Post #2153
For a twin plate it’s super narrow and compact and light ....the picture doesn’t do it justice Thumbs up
Posted 25th Jan 2019 at 20:20
blandy
Post #2154
So is this completely different to your old clutch? Because of the box I assume?
Posted 25th Jan 2019 at 22:04
Post #2155
quote:
[quote="blandy"]So is this completely different to your old clutch? Because of the box I assume?
Totally different Yes Mike ....no not because of just the Sequencial box it’s because my clutch plate is on the boarder (holding) not slipping with my single Superclutch pressure plate that has only 200kg pressure plate ...MOST ARE 300kg min
Sandy won’t have any more than 200kg pressure plate on his engine because of thrust bearing side pressure....
My Clutch did just start to slip and the only way to stop this and keep to 200kg pressure plate is to go twin plate with low pressure plate ...see see
Benefit as well is stays cooler also Thumbs up
Down side cost and weighs more but the goods outweighs the downs
Note ...you have limited space in a standard box though but this is a compact one so much thinner and would fit
PS ...the Sequencial box uses a 1x 23 tooth centre spline clutch plate that’s different to standard 306 Centre clutch plate but that’s easily changed by any good clutch plate manufacturer importer ...both my clutch plates in the first picture have been changed before sending
Posted 25th Jan 2019 at 22:27
Post #2156
Small update ...
Took me nearly 2hrs to assemble 63 parts in 19 small bags Thumbs down
Anyway it’s ready to go in apart from remote bias ajuster not seem fitted yet
Posted 27th Jan 2019 at 15:24
Post #2157
Floating brake cylinders...so say make Pedal box bias valve work ...let’s find out ...if not I have a inline bias valve as back up
Posted 27th Jan 2019 at 15:26
Post #2158
You can see underneath how the pair of new style brake cylinders work Thumbs up
Posted 27th Jan 2019 at 15:27
Post #2159
The servo / T4 master cylinder and original 306 pedals etc are 5.1kgs ...so new pedalbox is lighter than what I run now ...Thumbs up
Posted 27th Jan 2019 at 15:33
jmartos94
Post #2160
Stunning work mate, keep it up!
Posted 27th Jan 2019 at 18:30
Post #2161
quote:
[quote="jmartos94"]Stunning work mate, keep it up!
Thank you Jamie ...lots more to come in the next two months LOL
Posted 27th Jan 2019 at 18:38
Post #2162
Very small update
Clutch tool full metal to aid fitting my twin clutch and Sequencial box ....put my hand by the side to show the size ..so say this will fit triple clutch als because the splines are so long
Posted 28th Jan 2019 at 11:51
blandy
Post #2163
loving that pedal box - is it floor or bulkhead mounted?
Posted 28th Jan 2019 at 13:18
Post #2164
quote:
[quote="blandy"]loving that pedal box - is it floor or bulkhead mounted?
Floor mounted Mike Thumbs up
Posted 28th Jan 2019 at 16:54
Post #2165
What a total nightmare trying to remove a Servo with the engine still in place ...
Posted 28th Jan 2019 at 16:55
Post #2166
Remove x3 pedals with the dash in wasent anymore fun ...horrible......
This lot below weighs 5.45 kgs
Posted 28th Jan 2019 at 16:57
Post #2167
New Tilton 816 floor mount 4.15 minus top alloy plate and lots of brake / clutch pipes to make
Posted 28th Jan 2019 at 16:58
Post #2168
With plate off ...only just sat there ..4mm plate needs to go underneath to spread the load and pressure
Posted 28th Jan 2019 at 17:05
blandy
Post #2169
quote:
[quote="Day666"]
ah i see with the protective cover on all makes sense
Interested to see how you get on as hear alot of mixed reviews with pedal boxes although most race specific cars run them so clearly run them for a reason
Post #2170
Alloy mock up plate ....need to be much wider and (clutch foot rest) making on side Thumbs up
Sort of gives the idea
Posted 28th Jan 2019 at 17:08
Post #2171
quote:
[quote="blandy"]
quote:
[quote="Day666"]
It’s really for brake feel Mike and I need a hydraulic clutch for my Sequencial box.....100% missed my servo when I disconnected it ...I had to push the brakes so so hard when you saw me last time at Combe but got so much more feedback and never locked brakes up once ..this setup is designed for my front / rear callipers so fingers crossed
Posted 28th Jan 2019 at 17:13
Post #2172
Very small update ...
As I’m previous posts ...Removed the servo and made a alloy plate to bolt in place of the servo large hole to run Brake fluid reservoir pipes through
Posted 29th Jan 2019 at 22:47
Post #2173
Pipes code to stop me mixing them up LOL
Posted 29th Jan 2019 at 22:48
Post #2174
reservoir Fitted to Alloy made bracket
Posted 29th Jan 2019 at 22:49
Post #2175
Fitted to passenger side bulk head ...
PS ...black marker pen will be removed only used temp to stop mix up and while I wait for embossed stickers to arrive Thumbs up
Posted 29th Jan 2019 at 22:51
