Author | Subject: Day666 / 6 updates / 1% road 99% track/Race |
Post #3176
Posted 4th Sep 2021 at 15:44
Post #3177
Full carbon roof tried for fit …10/10 |
Posted 4th Sep 2021 at 15:46
Post #3178
Post #3179
Now with the roof off i can upgrade my roll cage so much easier and it gives me loads more light inside the car to work with and i can now rewire and make the welded floor supports for the paddle-shift floor mounts …then i can finally fit the Carbon roof last job after its had the stickers removed and a sand and re lacquer of 2k clear coat |
Posted 4th Sep 2021 at 15:51
Seasoned Pro Location: DoncastAAAAARGH Registered: 13 Jan 2008 Posts: 4,640 Status: Offline |
Post #3180
Awesome work!How much weight will you be saving? ________________________________________ Goldie the track car. |
Posted 4th Sep 2021 at 22:02
Post #3181
prism7guy wrote: Awesome work! How much weight will you be saving? Thank you Steve Just over 7kgs |
Posted 5th Sep 2021 at 14:27
Post #3182
Pump up Sucker weighed |
Posted 5th Sep 2021 at 14:28
Post #3183
Metal roof with 1kg Sucker inc Take nearly 1kg off for sucker |
Posted 5th Sep 2021 at 14:34
Post #3184
Carbon roof inc Sucker 1kg Take nearly 1kg off for sucker |
Posted 5th Sep 2021 at 14:33
Posted 5th Sep 2021 at 15:16
Post #3186
prism7guy wrote: Impressive savings! Yes I Was very surprised |
Posted 6th Sep 2021 at 08:03
Post #3187
Going to be busy again this weekend |
Posted 8th Sep 2021 at 19:31
Post #3188
Let project….support riser plate begin I need to raise the XAP paddle-shift / main -solenoid unit up 67mm at the front and 98mm at the rear Cardboard to Metal |
Posted 11th Sep 2021 at 17:22
Post #3189
Well first i had to remove the old cable handbrake support riser and prime it up so it doesn’t rust |
Posted 12th Sep 2021 at 20:16
Post #3190
Paddle-shift Support riser nearly finished 3-4 hrs left then drill some big holes to save weight and allow me to fix and hide the bolts …so it matches the gearshift support riser on the left of the pic Its given me loads of room to put a new Hydraulic handbrake or cable or both |
Posted 12th Sep 2021 at 20:24
Post #3191
Posted 12th Sep 2021 at 20:30
Post #3192
Posted 19th Sep 2021 at 14:15
Post #3193
Riser nearly finished |
Posted 19th Sep 2021 at 14:16
Post #3194
To match the gearstick….M10 [probolt]= Titanium bolts coloured blue … |
Posted 20th Sep 2021 at 18:47
Post #3195
Few £s here |
Posted 20th Sep 2021 at 18:48
Post #3196
OTT i know …..Fits a treat |
Posted 20th Sep 2021 at 18:50
Post #3197
Well as sad as i am wanting Blue Anodising rather than Red …This took 45mins of my life to remove without damaging… It was IP45 siliconed down / and sealed with both rubber gaskets and some kind of clear hard glue sealing the circuit board under neath …ohh that was fun - (not) Things i do for this obsession Off to the anodisers Monday |
Posted 2nd Oct 2021 at 13:27
Post #3198
Well thanks to Alex from DTA …now know about the new ECU im getting and will be available soon ….it basically does everything duel ..so V6 /v8 \v12I wont be running out of channels in the near future… All the updates inc new features should be ready by December I need fly by wire and other things to run my paddleshift |
Posted 5th Oct 2021 at 17:47
Post #3199
Because i wont be using a throttle cable anymore and need a Electric throttle control to move my 48mm jenveys for my paddle shift gear change I've managed to source one of these and they are not cheap …this is called the fly by wire throttle control and it blips the engine on paddle-shift up and down gear change on Sequencial gearbox without needing any clutch |
Posted 5th Oct 2021 at 19:23
Post #3200
This item connects to my Tilton 800 pedal box throttle and gives the signal to the throttle Actuator above rather than a throttle cable …It works similar to a TPS sensor This works in conjunction with the paddle shift and gear-lever if you dont want to use paddle shift only gear lever then Clutch will be used only to change down gear when using the gear-lever |
Posted 5th Oct 2021 at 19:29
