displaying posts 2851 to 2875 of 3423
Pages (137): first .. 114 [115] 116 .. last
Post #2851
pete_rallye wrote:
Day666 wrote:
pete_rallye wrote:
I'm confused! What are you making an airbox for?!
Hi Pete
I should of said project Airbox and making some items to assist the fitting of it LOL
I'm still confused, isn't the big carbon/kevlar bit the airbox?
Dry sump looks loads better like that!
Pete the back of the rear Airbox does not 100% line up with my Jenvey angle ...so I’ll mod it to fit ...Ryan had to make a 16 degree wedge up on his Maxi Replica also ...but I’ve got a cunning plan LOL
Pete the £78.00 delivered bits from Neil Brown / Pace arrived today and only orders them yesterday....
Posted 23rd Sep 2020 at 17:16
pete_rallye
Post #2852
Ah ok, I thought you were making an airbox to feed an airbox or something! Wouldn't it be easier to fabricate some angled spacers to alter the angle of the throttle bodies to be parallel with the airbox?
It always makes me chuckle when they put the red caps on the fittings but leave the other end open. I suppose it stops them getting bashed but seems ott to me!
Lap of the 'ring
Posted 23rd Sep 2020 at 20:41
Post #2853
I’ve been told not to change anything Pete
Sandy wants to back to back test the Airbox V the original setup Thumbs up
Also remember my inlets virtually straight and I’ve been told that was the 4th design / made manifold Before they got out what they wanted ...
Totally agree Pete ....Red caps make me smile
Posted 23rd Sep 2020 at 21:46
Post #2854
I want it to look along the lines of this Thumbs up
Posted 24th Sep 2020 at 09:13
pete_rallye
Post #2855
Should be good like and i'd be interested to see the results. My only concern would be induction noise tripping noise meters. I've had issues with a standard px600 type filter and it probably doesn't but i imagine those airboxes to help send the noise out of the front of the car!
Lap of the 'ring
Posted 24th Sep 2020 at 20:03
Post #2856
My induction Noise at mo is crazy loud so I hope not Pete ?
My exhaust is 86db but my induction is ear splitting and crazy with a ITG filter Thumbs down
Posted 25th Sep 2020 at 07:11
blandy
Post #2857
I believe Carl has done a few days at Snetterton with one of these installed on his race car and been ok
Posted 25th Sep 2020 at 11:05
Post #2858
I sold one to one of the Carl’s
Think it was Carl Grimsby?
Posted 25th Sep 2020 at 18:43
Post #2859
OLD PHOTO From 2years ago
Can’t believe how much difference dropping the engine and modifying the standard bumper to what I wanted and now I’ve got it being modified again by Fibreworx and made out of Carbon/Kevlar ..I’ve seen the progress today and I’m over the moon so far ...
Posted 25th Sep 2020 at 18:50
Post #2860
Older Photo again !!!!
What it looked like after I heavily modified it and it looks totally different again today as it’s all smoothed out and looks mega and going to weigh under 3kgs ....
Posted 25th Sep 2020 at 18:54
pete_rallye
Post #2861
My exhaust is borderline but its definitely induction noise that trips the sound meters, had it at Croft and Oulton in the past. Pain in the arse as there's not much you can do about it. I bought a carbon airbox that i've yet to fit to try and quieten it down.
Carl does run one of those filters yes but I don't think his engine is anywhere near the spec yours is. Its basically the overlap of the cams that does it, when the inlets and exhausts are open together, same noise thats going out of the exhaust but its unfiltered coming straight back out of the trumpets.
Lap of the 'ring
Posted 26th Sep 2020 at 00:20
Post #2862
Mike Blands Reveie air box and inlet pipe 100% made a difference but it won’t supply my engine with enough Air sadly ....I’ve only really gone to Combe so far but that will change soon Thumbs up
Thanks Pete
Fingers crossed
Posted 26th Sep 2020 at 13:31
Post #2863
Made this correct angled wedge to let the chap who’s making me a slide on back which I can graft on - giving me the correct trumpet angle as before and using the Carbon/ Kevlar back plate to hold the back of the trumpets as it did before but it was a alloy back plate ...
So say Sandy found if the back plate was at the back of the mouth of the trumpets it made more power ?...who am I to argue
I’m not doing much more apart From getting more direct cold air to the inlet ...I’m not changing Amy trumpet or back plate length as I want a proper back to back test
Posted 27th Sep 2020 at 18:05
Post #2864
Made a Polycarb template so I can 100% make sure the Airbox Will match the Jenveys
90 -95- 90 gap
Makes life so much easier and I can show the chap making the false Rear graft on angled rear Airbox
The alloy back plate in the picture won’t be used now Thumbs up
Posted 27th Sep 2020 at 18:10
Post #2865
Hopefully you can see the Satchell trumpets - they are different to normal trumpets as the back plate screws to the rear of the mouth with silly little 3mm dome head Allen screws
Well they did ?...not any more - I drilled and tapped them out to 6mm bolts as the 3mm once loctited were almost impossible to undo
Posted 28th Sep 2020 at 21:06
Post #2866
Now 6mm bolts to hold the Carbon /Kevlar back plate on
Posted 27th Sep 2020 at 18:16
Post #2867
You can see the size difference
Posted 27th Sep 2020 at 18:18
Post #2868
Here’s the mouth of the Satchell Trumpets ....the old alloy back plate and now the Carbon Kevlar Airbox will go to the rear flat of the front of the trumpets
Posted 27th Sep 2020 at 18:21
Post #2869
This is the old back plate ...hope you get the idea ?...the alloy in this pic is now gone and now Carbon /Kevlar Back box of the new Airbox
Posted 28th Sep 2020 at 21:07
Post #2870
It’s been a busy day working out the angles and getting everything sorted ready for the Airbox mod and trumpet install later on ...
Hopefully the new Carbon / Kevlar redesigned bumper will be here in 4weeks Fibreworx is finishing the filling and smoothing of the old one to make a mold
Posted 27th Sep 2020 at 18:31
Post #2871
This really has made my life so much easier Thumbs up
Posted 27th Sep 2020 at 18:34
Post #2872
You can see the silver second injector rail on the bottom at the front
Posted 28th Sep 2020 at 18:14
Post #2873
Finally getting somewhere with the Airbox ...
Two weeks and it should be back ?
Got the back section being angled and extended a little / modified in Carbon / Kevlar to match front
Got Satchell trumpets tapped out from 3mm to 6mm
Got a split overlap support billet back plate in 6mm being made to support inlet and back of the airbox -something the works cars did just before they stopped production ...because of vibration and heat / expansion...
Received the two stage filtered Air filter from a UK distributor via France and it was cheaper
Pic below -Bought a metre of Carbon / Kevlar cloth to give to my man to fabricate rear angled extension....
Posted 28th Sep 2020 at 21:09
Post #2874
New Airfilter
Posted 28th Sep 2020 at 18:19
Post #2875
Posted 28th Sep 2020 at 18:21
