Author Subject: Advice- GTI6 running on dta s40 ecu
davis100
I have a standard engine gti6 with magnet exhaust and de cat running dta s40 management a single coil pack and normal ht leads, I've had it mapped but it's a nightmare to start when cold, struggles to turn over pops and bangs and starts eventually if the battery has not gone flat, it won't idle when cold and has a misfire low down in their revs, when warm tho it starts like a dream and runs fine through their rev range, is this normal? Does it need to be mapped better? Is there anything else wrong?
Posted 3rd Feb 2016 at 21:34
needs the cold start map tweaking a bit by the sound of it.
Posted 3rd Feb 2016 at 21:45
davis100
Would that cause the missfire also?
Posted 3rd Feb 2016 at 22:42
Why have you changed to a single coil pack and/or running with a DTA with a standard engine with only an exhaust as a modification? It seems a bit overkill, but as Welshpug says, your issue is the cold start mapping.
Posted 3rd Feb 2016 at 22:55
RallyeP6
If it struggles to turn over and the battery and starter are good, sounds like you have too much advance while cranking. There are settings for cranking the engine over before it fires and starting tooth/position degrees.
Posted 4th Feb 2016 at 11:27
Take it ASAP to a good mapper !
Before you do some real damage ....Crazy
Posted 4th Feb 2016 at 14:58
Send me the map.
Posted 4th Feb 2016 at 15:16
put a virus in it which steals his bank information every time he gets in the car with his wallet
Posted 4th Feb 2016 at 15:21
It's tricky to get a 100% superb cold start map if you've driven it somewhere to be mapped as it won't be stone cold.
I'm running the same and in the cold, a bit of throttle when you start it and holding the revs up for 10 seconds or so works for me. If I don't it will die or rev lumpy.
  • Posted 4th Feb 2016 at 17:16
    I was gonna make it voice controlled so you have to shout 'Rikky's a c**t!' to start the car. Thumbs up
    Posted 4th Feb 2016 at 20:39
    fatlapit
    mines rubbish too, but 650 injectors and scatter spark just cant seem to make her idle until shes warm
    Posted 4th Feb 2016 at 20:43
    Shouldn't be an issue unless the injectors are particularly poor quality.
    Posted 4th Feb 2016 at 21:29
    fatlapit
    Had them tested by the manufacturer and by a specialist. Theyre fine. Only other thing is to raise the base pressure and hope it sorts it
    Posted 4th Feb 2016 at 21:32
    fatlapit
    Tbh my mate matty has the same issue on his 205 gti6 turbo. Maybe the idle stratergys on omex are rubbish.
    Saying that it will start and idle. But if you blip the throttle it will just cut out and not catch the idle
    Posted 4th Feb 2016 at 21:35
    Throttle enrichment and/or the tipout/fuel cut settings need tweaking.
    Posted 4th Feb 2016 at 22:04
    fatlapit
    Cheers bud
    Posted 4th Feb 2016 at 22:13
